Gas smell...yes I read the stickies
Old Feb 21, 2005 | 06:54 PM
greggie195's Avatar
So I have this bad gas smell so after reading the stickies I checked the rail hoses and they seem fine. However, right at 3 of the injectors I see gas, but its not spraying out, just sought of sweat. Is there a gasket there that can go bad? And how hard are they to replace? Thanks for all the info!
Old Feb 21, 2005 | 07:19 PM
internetautomar's Avatar
mod or sell?
o-rings are there.
they can go bad
Old Feb 21, 2005 | 07:35 PM
tripleGmax's Avatar
o-rings are there.
mmmmm onion rings.
did you read the stickies?
just kidding. It took me some time to pinpoint mine, its the rail underneath the intake manifold. very hard to see and impossible to replace without taking off intake manifold. but you can tighten it without taking it off. try that, i assume thats where youre saying its leaking. look in the stickies again the first link Dan put in there has pics, and its one of those that shows you what im talkin bout.
Old Feb 21, 2005 | 07:46 PM
greggie195's Avatar
mmmmm onion rings
Great Homer-esque line!
internetautomar: Thanks for the info!
On this picture at the top left, under the green injector cap(?), there is a small round piece of metal with 2 screws in it, that is what seems to be leaking on three of the injectors. I'm assuming there would be the o rings under them. Is there any special tips to replace them. Should I oil the rings first?
Old Feb 21, 2005 | 09:50 PM
sara92max's Avatar
Those are the pintel caps on top of the injectors. The orings have failed and you need to replace them. Replace all of them. It is hard to get those screws off of the pintel caps, so it maybe easier to pull the fuel rail itself, because you will need to use locking pliers to get the screws off.
Once you get the injectors out of the rail,install new upper and lower o-rings. Install the fuel rail back on first, be carfull not to damage the rubber insulators, then, use ALOT of vasaline and lube up the inside of the rail were the injectors go. Oil does not work well here, its a tight fit, and you can deform or tear the lower o-ring.
Twist and turn the injector in the rail as far as you can, them put the caps back on and let the screws drive it home.
Also, change all of the fuel lines (they look like crap) and the clamps. Besure and use fuel line for FUEL INJECTION......
Old Feb 24, 2005 | 09:15 AM
greggie195's Avatar
That picture was not from my car, I took it from one of the stickies. Well I had all the O rings replaced, and the thing is still leaking, not as much as previously, but definatly still wet. I have no idea whats causing this. This car is proving to be a real headache, I'm starting to regret getting rid of my 200sx. I've already put nearly $400 worth of work into this car in less than a month!
Old Feb 24, 2005 | 09:27 AM
Wiking's Avatar
Separate those issues mentally, hlps. Now leaking is very basic issue: either u have wrong kind of seals, or the seals ripped while inserting. Take out, buy new, try with better hope. Thats where we all stand...
One far away possibility is too high pressure. There is a regulator that should keep the pressure at 30 (wasit psi?). Hopefully does his job...
Dont let mechanics spoil u day. If that happens, it eats u whole life.
Have a nice day!
Old Feb 24, 2005 | 09:31 AM
greggie195's Avatar
The thing is that the old seals were not ripped at all they looked fine (to me anyway). I was expecting some ripped up o rings. Is it possible that the leak is comming from somewhere else and getting to these spots? But I only see it at 3 injectors, no trail or anything!
Old Feb 24, 2005 | 09:38 AM
tripleGmax's Avatar
here is how i finally found exactly where my leak was coming from.
let the car sit for like 7 hours (that way all gas has dried up). go start it up and then pop the hood. use the throttle to give it gas and inspect where the gas is coming from.
hope this helps, its how i found mine, since it was leaking underneath the intake manifold and i couldnt see it. i finally found it running down a pipe.
Old Feb 24, 2005 | 10:08 AM
Wiking's Avatar
The rail itself is a product that can leak from seams or have a hair thin crack. Highly unlikely, but possible. Anyway, the gas travels from that spot so that its not possible to locate the source.
Do as suggested by tripleG, dry first all. Maybe u can then wisely paper all around (thin one layer)put ign on and use bright light. The paper should hinder gas travel: the first spot to become wet is u problem area. Pump raises the pressure. Watch and locate.
There might be better ideas... think. Thin layer of smtg which shows where the leak starts, veeery thin layer of wood dust? Some spray which visibly interacts with gas, and is easy to get rid of later?
Matches ....nooooo.
Old Feb 24, 2005 | 10:57 AM
greggie195's Avatar
Thanks for the tips guys, Ill give them a try. I particually like the matches idea right about now!
Old Feb 24, 2005 | 10:52 PM
greggie195's Avatar
Success! At least I think. After a long drive home, after making some clamps extra tight, it seems like all the leaking is gone. And it was pretty cold today, around 25, and after driving there was NO gas smell. I just hope this work holds up! Again, thanks guys for all the info!
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
sdotcarter
Sep 2, 2015 09:53 PM
