Lost secondary systems
Old Feb 22, 2005 | 01:41 PM
landjet32's Avatar
Okay, I have a question for the group. I lost power to the following: radio, airbag, security system (this includes both the alarm and the keyless entry). Also, my seatbelts wont retract unless the ignition is running or switched in the on position. The secondary position on the ignition does nothing at this time. If I turn the car completely off and remove the key, open the door, the seatbelts wont retract at all, I have to keep the key in the ignition and turn it to the on position or open the door before i turn off the engine and remove the key. Im sure this is all related because everything I have mentioned here happened at th same time. BTW the airbag light is constantly on and im assuming its because it has lost power as well.
Any ideas where to start looking?
Old Feb 22, 2005 | 01:43 PM
Jeff92se's Avatar
I'm needing a caw
Fuses, then relays. But in all honestly, this is odd. Might be an ign switch problem
Old Feb 22, 2005 | 01:56 PM
internetautomar's Avatar
mod or sell?
Fusible link underhood also
Miket2006
Mar 1, 2021 03:55 AM
gigabyte
Jan 6, 2017 06:05 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
