Car Died when Driving And now it won't start... HELP!!!
Mar 2, 2005 | 06:16 PM
I have a 93 SE Auto, I pulled out of my driveway earlier, went about 25-30 feet and my car died. I tried to start it over and over again, but everytime i did, it would run really crappy for about 10 seconds and then die. I checked the fuel filter, drained it, and connected it. When i disconnected it, it started squirting gas out. I tried to restart it and now it won't run, it just cranks. I checked all the fuses, and they are all good. I'm not sure if it's the fuel pump or not, but any info. would be greatly appreciated.
Thanks, Eric!
Mar 2, 2005 | 07:50 PM
A motor needs air, fuel, and spark to run so you need to see which one it's missing. Unless there's a mouse nest in your air box then it's probably getting air so that's easy. I would check for spark next since it's fairly easy to do, look up instructions on google or something. You can check for fuel by installing a fuel pressure gauge. Lastly I'd check the engine codes to see if they tell you anything, that's in the stickies. Let us know after you check these things.
BTW: Was there any other symptoms before it died?
Mar 2, 2005 | 08:14 PM
Well, it was the fuel pump. I had problems previously, where it would not start for a few minutes, and then would. I would imagine that it was a weak pump and then it just died. The only symptoms were that it started to sputter and then died. I will say that Nissan was thinking very smart when they installed this pump, it only took about 20 minutes or so to change and was a cake walk! Thank you nissan!!! Thanks For the reply!
