Clutch Issues
Clutch Issues
Okay, I cannot get the car to go in gear with the engine running. I have examined the cylinders, replaced the master, and then bled and checked the slave. They seem to be in working order.
When the pedal is pressed, the slave cylinder moved, and seems to push the release lever. I watched it move while someone else pressed the pedal.
However, I still cannot go into gear. What's next? Throwout bearing? Clutch job coming?
how far did the slave move it should move at least 1 inch
did you blead both bleaders there one on the distrubution block that alot of people dont know about and sometimes that will cure the problem
could be the clutch, ive had to replace 2 clutchs do to part of the disc braking which would not alow the pp to fully disengage, one was on a max
Mar 12, 2020 12:06 AM
