Sea foam made my car sooo sluggish ???
Old Mar 8, 2005 | 11:16 AM
Brendan's Avatar
Hey guys, please refer to this problem first before adressing the sea foam problem http://forums.maxima.org/showthread.php?t=384886 so the car has a problem first of all, fuel injector? i don't know, but i figured before i brought it to a mechanic i'd try some sea foam as i know lot swear by it, thinking maybe i have a clogged injector, so i follow directions, let the vaccum line suck it up, let the car sit, let it smoke, drive it around, and my car is 10 times more sluggish and slower than before, to the point where i struggled to get up a hill from a stop at a light. Has anyone expirienced this before? Does this mean i did have a clogged injector and perhaps the foam made it a big worse instead of lossening the clog? help please guys....
Old Mar 8, 2005 | 11:19 AM
Jeff92se's Avatar
I'm needing a caw
Well for one, they way you used it, won't clean the injectors. You put it the gas tank to clean the injectors.
Old Mar 8, 2005 | 11:23 AM
Wiking's Avatar
Originally Posted by Brendan
.... made it a big worse instead of lossening the clog? help please guys....
Take out u plugs - what are they like now? Clean, put back.
Old Mar 8, 2005 | 01:01 PM
Brendan's Avatar
I don't really know what you mean, but the plugs are new and look clean still
Old Mar 8, 2005 | 01:32 PM
Scope's Avatar
Im izz sexay
He means take them out and check them. If they are all clean then put them back in. If one is dirty or has residue on it then that is the bad injector's location. It doesn't matter if you had just changed them if the injector is garbage then you'll see crap all over it.
Old Mar 9, 2005 | 12:23 PM
eric93SE's Avatar
If you had a lot of carbon buildup, then you may have given your 02 sensor a mouth full. There is also the possiblity that the 02 sensor was over heated. If its old you should replace it anyway.
Lakersallday24
Jun 16, 2019 01:35 AM
ah2002
Mar 9, 2016 01:42 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Blackwind
Aug 5, 2015 06:35 PM
