engine whine - VE
Old Mar 9, 2005 | 02:39 PM
Minty91GXE's Avatar
engine whine - VE
middle of engine, drivebelt side.
its not the belts, not the alternator,
disappears under higher rpm, loudest at idle, constant kind of whirring/whining sound, not too-high pitched, but high, not a squeal.
thought about power steering, but dont know how to confirm or rectify the issue. thoughts and advice are greatly appreciated.
thanks,
tom
Old Mar 9, 2005 | 02:58 PM
garbury's Avatar
ive got a whine too when in low rpms in first gear. I think its cool though, it sounds kind of airplane-like. Sorry I'm of no help though.
Old Mar 9, 2005 | 03:24 PM
subs1000w's Avatar
proboly power steering pump. mine whines at cold startup but goes away after about 30 secs
to confirm just remove the power steering belt and start engine if the sounds goone thats it
Old Mar 9, 2005 | 05:11 PM
DARHAW-MAX's Avatar
In my particular case, the whine was coming from the AC compressor belt tensioner. It actually seized up! I removed the belt for the winter since I obviously did not need the AC. Just last week, I replaced the tensioner with one that I canned from a local junk yard—after I “refurbished” it—and all is well. No whining noise. As a matter of fact, sine the AC belt tensioner failed, I am going to replace the one that provides belt tension for the PS pump belt. I am not saying that is your case, but it is definitely something to investigate.
Old Mar 9, 2005 | 05:29 PM
bhunter's Avatar
One of my three has a whine and it is definitely the power steering pump.
Old Mar 10, 2005 | 06:52 PM
Minty91GXE's Avatar
does it whine because its going out? or just because it likes to drive me crazy
Old Mar 10, 2005 | 07:02 PM
bhunter's Avatar
Not sure, but probably is going out. My daughter had a hose leaking that she didn't tell me about so the fluid got pretty low. By the time I got the hose changed it started this whine--hasn't gotten any worse for 2 months tho.
Old Mar 10, 2005 | 10:15 PM
Minty91GXE's Avatar
i looked through the old service records and it seems the car has been making this noise for.... 6 years? what! forget it
Old Mar 11, 2005 | 04:14 AM
bhunter's Avatar
I agree, my daughter has gotten used to it. I only notice it because I drive the red 92SE and hear the difference when she comes home. Of course she wouldn't notice gallons of any color fluid running under the car. She notices the stereo and luckily so far, the gas guage.
Old Mar 11, 2005 | 04:25 AM
Wiking's Avatar
...thoughts and advice are greatly appreciated.
thanks, tom
old fashIoned s t e t h o s c o p e: Screwdriver on engine, ear on handle. Easy to pinpoint mech noises.
Could be also u chain.
Old Mar 11, 2005 | 08:55 AM
Ninty-two-se's Avatar
May sound like a stupid thing.. but you did check the fluid level and top it off if it was low in the PS resevoir...Might be the first thing you did but just checking.
Old Mar 11, 2005 | 09:28 AM
subs1000w's Avatar
i think its the bearings that make the niose
Old Mar 12, 2005 | 04:29 AM
Wiking's Avatar
Take care: Next project engine whine ttrrroubleshootin...
Old Nov 29, 2006 | 05:18 PM
mikekantor's Avatar
Hey I'm resurrecting this! Anyone track down the problem conclusively?
I started hearing the noise a few weeks ago between 500-800 RPM, and immediately thought: p/s pump. The fluid was at about half so I topped it off but there is no difference.
After reading this I'll check the belts and see if I can track down a possible leak as soon as I have a chance.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
