Turn Signal Bulb
Old Mar 12, 2005 | 11:08 AM
MarkofCain's Avatar
Turn Signal Bulb
How do I replace the turn signal bulb?
Old Mar 12, 2005 | 11:15 AM
tripleGmax's Avatar
which one? most likely youll need replacement bulb, a screw driver and some time.
Old Mar 12, 2005 | 02:13 PM
AscendantMax's Avatar
it's pretty straight forward. for the fronts, you just need a phillips screw driver and some time like mentioned above. for the rear blinkers, you gotta open the trunk, and get to the lights from there. you'll see what i mean when you get back there.
Old Mar 12, 2005 | 04:26 PM
MarkofCain's Avatar
well its the front ones... do i just undo the screws and it will pop off?
Old Mar 12, 2005 | 05:05 PM
mtnbikeair's Avatar
Unscrew the screw from your corner light that is screwed onto your headlight bracket. Then pull from the bottom of the corner light because there is a little socket that holds it on, but it will just pop out, then take of the light bulb and switch.
Sir Tilus
Mar 22, 2016 01:49 PM
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
minsbang
Sep 11, 2015 08:48 PM
