Just bought an SE instrument cluster, How do I swap the odometers?
Old Mar 11, 2005 | 05:24 PM
aminus21's Avatar
UPDATE!!! Just bought an SE instrument cluster, How do I swap the odometers?
Hey guys, my trip meter on my 90 GXE is messed up so I bought an instrument cluster from a 90 SE Auto for my 90 GXE Auto. My trip odometer is messed up, and I think the white backround of the SE clusters looks really cool. I need to swap the odometer from my GXE, but keep the trip meter on the new SE. How do I take out the odometer??? I have taken out the clear plastic cover, and also the black part that goes around the cluster, that has the "Door-open", "High-Beam", "Check-Engine", etc., backlights. I can now touch all the needles. Would it be easier to turn back the mileage on the new cluster, or just swap the odometers?? And how??
Thnx.
Old Mar 11, 2005 | 05:33 PM
GRNMAXDMON's Avatar
there should be screws behind it so that u can swap the odometers.
Old Mar 11, 2005 | 06:29 PM
mtnbikeair's Avatar
First start by taking apart your broken one, so if you mess up you havent dug yourself into a deep hole. But there should be like two screws on the back that line up with about where the odo is and then it just comes right on out. No tricks or anything.
Old Mar 11, 2005 | 08:32 PM
expressinme's Avatar
be careful, cuz i did this like 3 weeks ago and my gauges stop working or just started sticking
Old Mar 11, 2005 | 08:55 PM
HTPerformance's Avatar
If any GXE folk want to do this too, I have a spare VG SE cluster around... PM me.
Brian
Old Mar 11, 2005 | 10:01 PM
Harvs94max's Avatar
two screws a little harness and i think its a tight squeeze coming out you might need to remove the gauge face overlay on the temp gas gauge side ive got like five clusters every one cept the digy sitting in my garage so if you f anything up i can send you parts
Old Mar 12, 2005 | 11:40 AM
aminus21's Avatar
UPDATE!!
Bad news.. Ok, I was able to switch the odometers, and get everything back together. I then put the cluster on top of my steering wheel, and connected the 3 harnesses to the cluster. I went for a test drive, and the odometer and speedometer work, and all the lights work, but the fuel gauge and temperature gauge doesnt work!!! I then plugged in my old cluster, and the temperature gauge shot up to the middle, and the fuel gauge went to the correct reading.. IS my new SE cluster useless?? I didnt plug in the other connectors for the cruise control, mirror adjusment, hazard switch, etc. but I dont think it makes a difference.
Would it be possible to change some internal stuff to make the SE cluster's fuel and temperature gauge work?? Highly unlikely, but maybe when I took off the fuel and temperature screen to remove the odometer I messed something up.. I dont know, but Im pissed.. All that work..oh well
Old Mar 12, 2005 | 12:18 PM
Open up the SE cluster and check everything.
Do you know that it was a functioning unit before hand?
I think you could also switch out the gauge assemblies into your GXE cluster, in case some of the SE wiring is bad.
Brian
Old Mar 12, 2005 | 12:50 PM
aminus21's Avatar
Brian
No i got it from the junkyard.. Can I just switch the gauge assemblies?? Is everything else the same??
Old Mar 12, 2005 | 12:56 PM
im 80% sure, i know that is how some people have put the speedo into their 125mph clusters, so the other guages might be the same.
Brian
Old Mar 12, 2005 | 04:02 PM
GRNMAXDMON's Avatar
Brian
yeah its the same cuz im usin' my 125mph cluster with the 145mph SE gauge faces and it works fine and reads my mph correctly. now i've noticed that the few people that have done the same as me had to calibrate the needles cuz for some reason the '92-'94 SE clusters r different in calibration than the GXE clusters "so they say". i didn't have to do that to mine. i just swapped them in and they worked just fine. i also have a spare '91 SE gauge cluster laying around if anyone is interested.
Old Mar 12, 2005 | 04:19 PM
mtnbikeair's Avatar
Check where the screws are on the back that hold on the gas gauge and the temperature gauge because the bolts that hold them on actually have something to do with the working of the electronics, so clean where the bolts sit, and that should help it work again. I had trouble with my speedo not working, and i cleaned where the screws hit the green electical sheet thingy and it fixed it.
Old Mar 12, 2005 | 05:18 PM
aminus21's Avatar
Well, I cleaned and tightened the screws and the fuel and temperature gauge started working. You were right mtnbikeair. Thanks a lot everyone..
After I fixed it, I tried removing the 3 gauge faces (temp/fuel, speed, and tach), and screwing them on to my old GXE cluster, it fit perfectly put when I put it in the car, it lighted up green, instead of white..
Old Mar 12, 2005 | 05:24 PM
GRNMAXDMON's Avatar
take off the bulbs with blue covers from the SE cluster and put them in ur GXE cluster.
mvm062
Nov 30, 2020 09:00 AM
Max139617
Sep 6, 2015 06:02 PM
A32goldylocks
Sep 2, 2015 06:39 AM
