unlock button on the driver side problem
Old Mar 15, 2005 | 10:07 PM
mofoaka's Avatar
..so i have a problem with my unlock/lock button on my driverside..
basicaly when i push the unlock button,, it unlocks and then locks.. if i hold the unlock button and keep on the button, it stays unlocked. push the unlock twice and it'll unlock. what is up?
Old Mar 15, 2005 | 10:21 PM
michaels'max's Avatar
sounds similar to my door lock problem except that I've never tried holding down the unlock switch. have you ever noticed when closing the doors that sometimes the doors lock themselves? with mine (92 nissan max gxe) it almost seems like it's possesed or has a mind of it's own. I've already posted my question, if yours is similar check out the thread that says "door locks? window won't roll down?". I don't have any information on the problem other than what other users have told me. I guess it could be the actuator in the door or wiring. Sorry I couldn't help more, If you get it fixed let me know what you did.
Old Mar 31, 2005 | 06:58 AM
RMAX's Avatar
Did you fix it. My door lock will not unlock and I crawl thru the passenger door. Will attempt to take off the door panel (if possible with the door closed) this week-end. Also a friend of mine said that maybe someone tried to use a slim jim to break in but disconnected some thing or dislodge a lever maybe even a cable.
Old Mar 31, 2005 | 07:23 AM
tripleGmax's Avatar
you wont get the door panel off with the door closed. there are two hidden screws when the door closes.
Old Mar 31, 2005 | 08:04 AM
mofoaka's Avatar
no updates on the door lock yet, i'm thinking its the wiring or the switch itself. not sure yet but i'll take it apart. it does seem like its possessed.
Old Mar 31, 2005 | 12:26 PM
waffqle's Avatar
I believe you've got a bad Door Lock Timer. I had the same problem. Supposedly it's very common in 3rd gen Maximas. The part is a little grey box with a couple relays in it. It's located under the dash on the right side of the steering wheel. There is a wiring harness attached to it and there's another black box with a wiring harness next to it.
I've heard the part is the same in all 3rd gens. (I'm not 100% on that but I know mine is a 93 and I replaced it with one from a 92.)
The dealer wanted about $75 for a new one, but I ended up getting one from someone on the forums here.
I may have just gotten ahold of a new guy or something, but it's worth mentioning that when I called the dealership I was originally told that the part didn't exist! They weren't able to locate it until I gave them the exact partnumber. (There is a sticker on the box that says "Door Lock Timer" followed by the part number.)
Hope this helps!
fastcarny
May 18, 2020 10:40 AM
boomerbrian
Nov 8, 2015 05:10 PM
rtirbany
Sep 8, 2015 11:46 AM
shaunkey1
Aug 18, 2015 10:09 PM
