heater blows cold air
Old Mar 18, 2005 | 07:45 AM
Anttron06's Avatar
my heater in my 94 maxima SE blows cold air. it could be a number of things such as the heater core, or the thermostat. does anyone have or had the same problem with their car? please send instructions or info on how i could check to see what the problem is. email me at antnjenn71603@netscape.net or post me on this thread. thanks every1
Old Mar 18, 2005 | 08:08 AM
Wiking's Avatar
Anothor way is DIY comb pages one month ago: plenty of threads...
Main reason is air in the system. Read stickies how to bleed.
Second is u valve or its vacuum hose:
http://www.cardomain.com/memberpage/748507/8
online manual:
www.autozone.com
Old Mar 18, 2005 | 08:18 AM
internetautomar's Avatar
mod or sell?
first check your antifreeze level.
when my antifreeze gets low I lose some heat.
Do you get heat when the car is moving?
do you have the lever on the left side of the climate control in the down position?
Old Mar 18, 2005 | 08:24 AM
Wiking's Avatar
...when my I lose some heat....
Main reason is air in the system "antifreeze gets low". Read stickies how to bleed
Old Mar 18, 2005 | 08:33 AM
mod or sell?
I only have to add, no bleeding has been required :P
Old Mar 18, 2005 | 08:35 AM
92SE_Dave's Avatar
I have a similar problem but with a twist.. maybe someone can help me..
I DO get heat.. no problem.. but if for example I have the heat set to window defrost vents, I get hot air blowing on the windshield, but I also get COLD air coming through the console vents at the same time ???
Old Mar 18, 2005 | 08:46 AM
Wiking's Avatar
Read u mail.
That is a feature, explains FSM.
Internetautomator: wasser aux, buenos aires in... if not, then tubing collapses and in the end whole engine block is sucked inwards ...and maybe becomes 850cc fiat. Oh boy, dont want that to happen for my friends. take care.
Old Mar 18, 2005 | 10:48 AM
Alex_V
Some times my heat works and some times it doesnt (or not at all for now, its still recovering from our wreck ) When it doesn't I just look for the relay under to hood, its on the firewall, dead center, take off both tubes and put them back on solves my problem. I'm thinking my tubes are cracked or bad or the relay is. BC I hear a sucking sound near the relay and it lessens if i put pressure on the tube. Im thinking a new relay in a few months (or when it gets cold, not much of a need for it now) or a zip tie will do.
GL with your problem, hope I helped.
~Alex
Old Mar 18, 2005 | 10:55 AM
Wiking's Avatar
~Alex
Dunno what u are speaking about.
Read: http://www.cardomain.com/memberpage/748507/8
Old Mar 19, 2005 | 08:41 AM
Anttron06's Avatar
i dont get any heat whether im moving or idle, no heat blows.
Old Mar 19, 2005 | 08:53 AM
Wiking's Avatar
So what have u done about it? Have u opened The hood?
Old Mar 20, 2005 | 02:27 PM
Misery's Avatar
That's the case with my 91 Max. what does that mean?
Old Mar 20, 2005 | 05:23 PM
mod or sell?
that you are low on antifreeze and or you need to bleed the system of air pockets
Old Mar 21, 2005 | 07:23 AM
LMaRiE91MaXiMa's Avatar
I own a 91 SE and when my antifreeze got a little low, I began losing heat as well. The heat became intermittent (i.e. blowing normal heat for like 5 minutes, turning cold, then warming up again, only to turn cold again)
I had my radiator flushed and filled (it was at the beginning of winter so I was just doing it as winter prep) turns out that, that did the trick. Heat has been hot as hell (like it normally is).
Old Mar 21, 2005 | 07:28 AM
...but I also get COLD air coming through the console vents at the same time ???
I dunno if this will help or not, but it might - There's a lever/switch to the left of the thermostat/fan control. It goes up and down and theres a picture of the guy with wavy lines for air on top...and on the bottom just the guy with no wavy lines of air. When the switch is set towards up (the pic with the lines showing air) that means that it is sucking in air from the outside and blowing it through your vents...when its down its not blowing in air from outside. That MIGHT be why you're getting cold air coming in through the console vents, but then again I could be wrong...
Old Mar 21, 2005 | 07:36 AM
Alex_V
Brian- its the 2 tubes connected to 14. the left on in the pic is either cracked or loose, and it sounds like a sucking sound. So to fix my problem I just push the vacume tube twords the relay. Something right there has to be replaced, and I'll get to that sooner or later. Thanks for the link
~Alex
Old Sep 4, 2006 | 02:42 PM
BANDIT1's Avatar
mine does the same but when i change it to 85 it does get hot 84 goes back to cold
Old Sep 4, 2006 | 02:58 PM
BANDIT1's Avatar
I have a 98 gls with climate control
Old Sep 4, 2006 | 03:40 PM
sublunary's Avatar
1. wrong forum, this is third gen 89-94
2. people dont respond well when old threads are resurrected
Old Sep 5, 2006 | 05:03 AM
mod or sell?
1, you're right he needs 4th gen (95-99)
2. sure we respond, but he won't like the answer.
he needs a new control head.
Old Sep 15, 2006 | 05:50 PM
witstick's Avatar
Hi ,
My 93 max se also blows cold air out the dash vents when i have my defroster on, and my switch is set to the lower position, not outside air position, what causes this? its very annoying....Thanks, Chris.
Old Sep 16, 2006 | 05:58 PM
mod or sell?
Broken cable maybe
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
Justin Kroll
Oct 1, 2015 07:03 PM
