Alternator going?????Need help
Old Mar 23, 2005 | 07:38 PM
diiesel21's Avatar
Today well i was driving home from work i notice when my car is not in gear, the gauge light,clock and radio dims but as soon as i give some gas it brighten up again. do you think it the alternator ?
Old Mar 23, 2005 | 08:09 PM
maxima92se's Avatar
When my alternator went out, the battery light was on. I was only able to drive it for a little while and everything was just dimming and no matter how much gas i gave it its was only getting worse. And i have lost my alternator twice and both times i never had a warning sign like that. I hope this helps.
goon9's Avatar
that and your battery.
Old Mar 23, 2005 | 08:16 PM
Maximan190's Avatar
yea thats your alternator, does it also make a whine noise too?
Old Mar 23, 2005 | 08:23 PM
92SE_Dave's Avatar
I think it is definately alternator related, and probably a bad alternator. But also if you're idle is too low, like below 600 - 700, alternators need a minimum speed to rotate.. so that could also possibly be it.
If you do change it, unless your battery is fairly new, then replace it also. Bad battery and alternator go hand in hand, when one goes it will take the other down with it.
Old Mar 23, 2005 | 08:25 PM
diiesel21's Avatar
yea it does , i check the battery its good , damn i need a alternator
Old Mar 23, 2005 | 08:28 PM
diiesel21's Avatar
i was thinking that too, thanx for the help
Old Mar 23, 2005 | 09:03 PM
Ninty-two-se's Avatar
Damn, I'm having this problem too... but just the headlights dim... Hopefully its just my battery or too low idle... Since I have no time to work on my car(s) at the moment!
Old Mar 23, 2005 | 10:46 PM
Wiking's Avatar
Typically alt is floating: add a ground wire to chassis or engine block from alt shroud. The possibility is 50/50 between regulator /brushes /grounding.
After changing the new alt, this floating situation becomes fixed: One starts to think that the old alternator was bad, although it was only the grounding issue. It will return one year later, and ruin the battery.
You may test his by adding a jumper wire. Whatever the result, if you want long lifetime you add one gnd wire.
Check for details: http://www.cardomain.com/memberpage/748507/10
Old Mar 24, 2005 | 07:35 AM
internetautomar's Avatar
mod or sell?
it's your voltage reg malfunctioning, which is internal to the alternator.
Old Mar 24, 2005 | 08:46 AM
eric93SE's Avatar
Or it may simply be a loose belt
My alt has 130k miles + on it and still running. I opened it up a couple years back, and its definitly on its way to mechanical failure.
Old Mar 24, 2005 | 12:12 PM
diiesel21's Avatar
i'm going check all these today and see whats what, cause alternator aint cheap.
TallTom
57
Oct 14, 2025 05:16 PM
