question about sunroof glass
Mar 28, 2005 | 09:00 AM
im just wondering, i found out that my sunroof has 2 cracks in it, it is in the 2 rear corners of the glass, but it does not leak, i think that it has 2 layers of glass, kinda like the new windows in houses are made, with some kinda gas in between them, so condensation doesnt occur, does anybody else have this problem???? with the sunroof glass cracking??? id say from expansion and contraction over the years.
Mar 28, 2005 | 09:06 AM
I have one nice crack down the center about 4 inches long, but it also does not leak.
Mar 28, 2005 | 10:17 AM
I had a perfect sunroof in my GXE and spare sunroof (from my parts car) but when I was painting the GXE I sat something on the sunroof a little too hard I guess and cracket it. I put the spare sunroof I had on it so I could sell the car.
I get the 92SE and it already had a crack in it but luckily Craig got me a new sunroof from therealgoon9 and another member on here...so now I have no cracks .
but yes I did have 2 cars with cracked sunroofs.
Mar 28, 2005 | 02:56 PM
it must be a problem that nissan had, or it is just from contraction and expansion. but the only good thing it that it will not leak through the glass because of it is tempered, meaning, that it has 2 peices of glass with a plastic piece in the center, just like your windsheild has.
Mar 28, 2005 | 11:41 PM
I have had 3 cracks in my 92SE sunroof for about 4 years now, and never a problem...well except for the weathered seals, which squeel, however thats a different post, on a different day.
Mar 29, 2005 | 06:34 AM
i got a crack about a foot long along the back side of mine. it was there when i got it. the crack dosent leak, but the one corner does when i wash the car. crappy rubber seals
Mar 29, 2005 | 07:18 AM
ya, same with all old cars and the t-tops, the leak because of the old and cracked rubber, always remember to change your rubber guys!
Mar 29, 2005 | 09:04 AM
i have 2 cracks in each layer or the sunroof
Mar 29, 2005 | 09:27 AM
it still dont leak though right??
Mar 29, 2005 | 09:31 AM
Its funny that you posted this thread now cause I JUST noticed a crack about an inch long right near the right rear corner of my sunroof - I am so PISSED about it....
It rained out ALL day yesterday and I have not noticed a leak, luckily.
Just outta curiousity...how much does it cost to replace the sunroof?
More specifically:
How much for the glass itself?
Is it hard to replace the glass yourself?
...or if a professional should do it, how long does the job usually take?
Thanks guys, .orgers ROCK!
Mar 29, 2005 | 10:03 AM
nope no leak at all
Mar 29, 2005 | 05:15 PM
glass would probably be expsenive, expecially that kinda glass, as i said, it is safety glass, so it wont leak. i would say go to a junk yard, or dont even worry about the crack. it usually happens automatically from heat-cold. over a couple years, i would just leave it, but if you wanna change it, check out a junk yard for the glass, or if you really wanan spend the money, get a new one.
Mar 29, 2005 | 06:07 PM
have a friend with a 92 se maxima, his always cracked out of no where..
Mar 29, 2005 | 06:28 PM
mine has no cracks but leaks as hell. as soon as i wash the car or a littlee bit of rain comes down then its over!! better start wiping!! really makes me mad. anyideas.
Mar 29, 2005 | 07:44 PM
did you check the drain??? it may be clogged, or it may be cracked, or maybe a bad seal??? check all of these
Mar 29, 2005 | 07:47 PM
bought mine with cracks...found good glass at the bone yard and swapped it out
Mar 29, 2005 | 10:20 PM
just wondering, can the weather rubber seals be simply replaced or does it have to go back to nissan
Mar 30, 2005 | 07:56 AM
id say you have to go to nissan for that. im not sure thought, but id say that you have to, do a google search!
Mar 30, 2005 | 08:14 AM
Quote: glass would probably be expsenive, expecially that kinda glass, as i said, it is safety glass, so it wont leak. i would say go to a junk yard, or dont even worry about the crack. it usually happens automatically from heat-cold. over a couple years, i would just leave it, but if you wanna change it, check out a junk yard for the glass, or if you really wanan spend the money, get a new one.
Thanks...i was just curious - I'm just gonna leave the crack there (its still small anyway and not leaking...so why the spend the $$$)
Mar 30, 2005 | 07:27 PM
exactly what i said, i have 2 cracks, one in each rear corner
