rough idle until warm 91 max... any ideas?
When was your last tune-up??
fouled plug(s) and or an arching plug wire(s) could be the culprit! when my O2 sensor was bad the car had a kinda rough idle when I used to start it up in the morning.
Originally posted by pan6ther9
I have a 91 max se and it idles roughly until it warms up (usually 4-5 mins) Does anyone have any ideas i can try? Thanks!
Not enough air is coming into the intake, so the mixture is rich and the idle low. Either deposits are blocking the flow, in the TB or AIV (air injection valve), or the AIV isn't doing what it's supposed to. The first thing to do is to make sure everything is clean, and then properly set the base idle speed (AIV disabled) when the engine is at full operating temp. If this doesn't cure things, then you have to begin more formal diagnostics to determine which components aren't functioning properly.
Originally posted by brubenstein
What is the idle speed when cold? It should be ~1250 RPM.
When I start my car after its been sitting all night, it idles around 1450 ------ then after 12 seconds, drops to 1250.
Is that okay or abnormal?
Unclejunebug
04-02-2016 05:42 AM
