Transmission issues
Transmission issues
So I dont know anything about transmissions, thats why im asking my favorite people. I just got a 92 SE 5 speed, and it drives good, the clutch has pressure on it. But if i am rolling and go to put it into first, say like coming up to a stoplight and the cars start moving it will grind, i have to come to a complete stop to get it into first. And also the catch point on the clutch is really close to the floor, like you move it like the tinyest bit and it catches ( alot of people say that is good tho). So people i have asked have given me two answers that it could be the clutch, and one dude told me it could be my synchros. SO does anyone know?
same with my 92 , check you're slave cylinder for leakage pull back the rubber boot... i replaced the slave and master . and it stopped .....If u grind try pusing the clutch in twice before u shift , worked for me especially in first gear , u might also want to adjust the clutch pedal
if it only grinds going into 1st its the 1st gear syncro if it was a clutch issue you would have issues in all gears
2 of the 4 5spds ive had in my car had this issue the current one also grinds going into 5th
the 1st one i had rebiult when it got locked in 2nd and the friend i had fix it replaced a few parts total about 400$ but didnt replace any of the bearings the syncros and gears from nissan are 60-80$ a peice
you can get a rebiuld kit from drivetrain.com for about 200$ but it dont come with the syncros you have to call them and get them and they only sell all or none and for all 5 stncros its about 250$ but you can go to the dealer to get them separate
sctludwig
Sep 1, 2022 01:32 PM
The Wizard
24
Oct 1, 2015 08:47 PM
