how to get antenna out?
Old Apr 5, 2005 | 10:48 AM
Tonyklem's Avatar
how do i remove my antenna from my 92 se? i got it unscrewed from the trunk, i dont kno how to get the actual antenna off of the car.
Old Apr 5, 2005 | 10:59 AM
maxrailfan1's Avatar
Open trunk lid. Remove power antenna-to-body mounting nut. Remove or push aside paneling. Disconnect the antenna lead and the electrical connector from the power antenna assembly. Remove antenna mounting nuts/bolts and remove antenna from vehicle.
Old Apr 5, 2005 | 11:04 AM
Tonyklem's Avatar
i cant get the mounting nut off. thats the silver ring on the outside of the car right?
Old Apr 5, 2005 | 11:17 AM
Yup, that is the silver ring. Try using some needle nose pliers to remove the ring. Stick the pliers into the slots in the silver ring and turn.
Old Apr 5, 2005 | 11:53 AM
Drivin Maxima's Avatar
you might even need to try channel locks........thats what i had to do cause mine was really really on there and I had to break it loose. good luck
Old Apr 5, 2005 | 12:04 PM
Tonyklem's Avatar
well i got that off... but now i cant get the unit out because the antennea wont retract (reason im taking it out.) i dunno what do try now
Old Apr 5, 2005 | 12:38 PM
that was the problem i had to deal wit......I just worked at it a lil bit and wiggled it out. If i can remember, I think I was gettin held up by the wires in there, like they weren't lettin me pull it all the way down.
Old Apr 5, 2005 | 12:49 PM
Vadim-93GXE
http://www.4dsc.com/articles/exterio..._antenna.shtml
Old Apr 5, 2005 | 01:15 PM
MAXI's Avatar
so it doesn't retract....do you hear noise from the antena motor when you turn on/off the radio?
if your power antena runs but the mast does not go down....you might be able to push the mast down manualy. slowly and carefully though.
Old Apr 5, 2005 | 06:16 PM
Tonyklem's Avatar
no the motor doesnt run at all thats what im takin it out for. i gotta see whats wrong with it.
*edit*
that site didnt help because my antenna wont go down at all so i cant remove the assembly because the antenna is sticking out of the hole.
Old Apr 5, 2005 | 06:58 PM
toddyfresh's Avatar
if ya need a motor i got one cheap
Old Apr 5, 2005 | 06:59 PM
Black92GXE's Avatar
Boomer Sooner
My question is where is the best place to get replacement parts
(motor or mast or both) for these antenna's?? ebay? nissan?
Old Apr 6, 2005 | 08:16 AM
MAXI's Avatar
*edit*
can you push it down manually?
Old Apr 6, 2005 | 08:17 AM
MAXI's Avatar
i got mine from junkyard
Old Apr 6, 2005 | 12:10 PM
Tonyklem's Avatar
no i cant push it down manually. its stuck completely...
i think im gonna buy the one from toddy and just take a hack saw to this one
Old Apr 6, 2005 | 01:32 PM
MAXI's Avatar
does it come with the antena mast?
Old Apr 6, 2005 | 01:44 PM
usmanasif's Avatar
eBay is a good place for the mast. Got mine there.
Old Apr 7, 2005 | 04:49 PM
Venumb's Avatar
Chances are, the plastic gear itself broke and is down inside the motor housing. I replaced my antenna about a year ago. I thought I got all of the old plastic gear removed from the motor but there was still a few incnhes of it left in the housing. I was too lazy to tear out the motor (it's a VERY confined space..especially for my big hands..lol) and just lived with the antenna retracting NEARLY all the way.
Old Apr 16, 2005 | 01:16 AM
jakedubb's Avatar
ive been just using the antenna built into the window and it works fine. My antenna broke and i just pulled it out.
MikesChevelle
Nov 23, 2024 11:17 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
