oil problems???
Old Apr 8, 2005 | 09:07 AM
vansskaterfreek's Avatar
oil problems???
the dipstick is just fine, but when i opened up the oil additive pipe thingy, where you put the oil into your car after an oil change, there was this white gunk in the cap and some was in the pipe, i really dont think this is good at all. could it be a possible water leak???? oil build up???? but is was white, or a cream color, doesnt look good, it only was in that tube, it didnt show in the dipstick, so just buildup???
Old Apr 8, 2005 | 09:28 AM
-shock211-'s Avatar
good question! i have this same shiet.
if i knew the answer i'd help you.
Old Apr 8, 2005 | 09:36 AM
Jeff92se's Avatar
I'm needing a caw
Uh oh. Take a sample of the oil and get it anaylzed by Blackstone Labs. $18 to get this done.
Could be nothing. But it could be a headgasket leak. How is your coolant level?
Old Apr 8, 2005 | 10:19 AM
-shock211-'s Avatar
Originally Posted by ace ventura
reheheheeealllyyy
i would suspect that as well but my coolant level stays the same and i get the white foamy stuff on my oil cap too. so that's why i don't have a clue as to what causes this.
Old Apr 8, 2005 | 11:45 AM
bhunter's Avatar
Generally that means water in your oil. COULD be just condensation. Have you done a lot of short trips? A longer trip tends to evaporate the water that condenses in the oil sometimes.
Old Apr 8, 2005 | 12:03 PM
Michael's Avatar
Back in a 3rd Gen.
if its fine at the dip stick but is only milky at the valve covers then generally its condensation.
I would think (then again I am not thinking straight today) that if it were a head gasket it would be milky in the crank case (where the dip stick goes) as well as under the valve cover.
Old Apr 8, 2005 | 12:08 PM
toddyfresh's Avatar
i had this problem also when i first bought the car but after driving it all the time it just quit so i assuming condensation
Old Apr 9, 2005 | 06:21 PM
Will's Avatar
I get that crap all the time in the winter. It's condensation, and it builds up more when you're running short trips in freezing temps.
Old Apr 10, 2005 | 07:05 AM
maximaboi's Avatar
if its NOT the head gasket then run an engine flush through it next oil change and that should take out all of that water and you shouldnt have that problem again, at least for a while.
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
