VE thermostat temp
Old Apr 8, 2005 | 07:03 PM
GreenMaxVE's Avatar
VE thermostat temp
Does anyone know the correct thermostat temperature for the VE30DE? I have read some sources saying 170 and others saying 180. What's the advantage to choosing the other temp thermostat? Thanks
Old Apr 8, 2005 | 08:52 PM
subs1000w's Avatar
i think stock is 180 and wouldnt worry about the differnce between the 170 and 180
Old Apr 8, 2005 | 08:55 PM
MrGone's Avatar
180
becareful though, go too cold and you can cause premature engine wear.
Old Apr 9, 2005 | 03:41 PM
eric93SE's Avatar
Try to get the 170. I think Arron test some of the 170's available and found out they were still opening at 180. 180 is stock, but I think there was a TSB that said for performance to use the 170.
Just make sure you get a failsafe thermostate, its worth the extra $10 or whatever.
Old Apr 10, 2005 | 03:28 PM
Akuma2001's Avatar
Where would one be able to aquire a 170 thermostat?
Old Apr 10, 2005 | 05:25 PM
Mizeree_X's Avatar
Getting back to his roots
Nismo sells a 160 one for $55.
Old Apr 10, 2005 | 08:55 PM
eric93SE's Avatar
well stant sells a failsafe 170 (pepboys), but OEM seems to be much better quality. Maybe call the dealer and see if he has heard of it.
Old Apr 11, 2005 | 04:29 PM
Akuma2001's Avatar
Is that safe for the car? I read that cars have to run at a specific temp. in order for it to run optimally. or is 20 deg. not going to make a difference?
Also, will the thermostat cause the coolant to flow sooner in order to keep the engine colder than it usually would?
Old Apr 11, 2005 | 05:16 PM
Akuma2001's Avatar
I see that Aaron92se has a 150 deg. thermostat. Does anybody know where he got it from?
Old Apr 11, 2005 | 09:31 PM
eric93SE's Avatar
Its from another car. He had to modify it to fit. But he confirmed the opening temp. before using it.
Old Apr 14, 2005 | 11:20 AM
Aaron92SE's Avatar
NWP Engineering.com
From a Nissan dealership in Puente Hills, CA. I ordered it. It's a Nismo one that I had to spend $55 on. During the winter, it took way too long for my car to heat up without a Tstat. I removed it a long time ago b/c of the bracket racing I did. Just another way to make your car more consistant in the 1/4 mile. With my Nismo Tstat and high speed cooling fans turned on, I can keep my car's temp below 165 at all times in any kind of heat. It helps. You can't do that with the stock Tstat.
Old Apr 14, 2005 | 11:21 AM
Aaron92SE's Avatar
NWP Engineering.com
That was the 160 Tstat I use to have. That came from another car at Auto Zone. The orifice was too small and it was impeding my flow. So I yanked it out.
My advice to anybody wanting a new Tstat. If you don't race your car like I do at the track, then get a 170 fail safe nice quality Tstat and you'll be set.
Old Apr 16, 2005 | 06:33 PM
Akuma2001's Avatar
Would any Nissan dealership be able to order that part? If so what's the part number?
Old Apr 17, 2005 | 04:49 PM
Aaron92SE's Avatar
NWP Engineering.com
Not any dealership can get you Nismo parts. Sorry, it took so long for a response. I was out of town. Here is the information I saved on my computer:
300ZX 1984-1996, Maxima 1985-1994, Pathfinder 1990-2000, Pickup V6 1990-1996, Frontier V6 1998-current, Xterra V6 2000-current
Nismo part # 21200-RS580
$67.77 from Nismoparts.com
$70 shipped from Courtesyparts.com
I ordered mine from Puente Hills Nissan in Southern California and they shipped it to me. I don't have their number, but I remember getting it for around $60 shipped.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
asianstyle
Sep 10, 2015 11:30 AM
