will these tires fit??
Old Apr 8, 2005 | 09:55 PM
Winds50's Avatar
I was driving today and blew out my front drivers side tire... so i need to replace it. I have 2 brand new 195 60 15's in my closet that I got for my saturn right before it was totaled... the stock tire is 205 65 15... will these ones i have in my house work, will it look stupid, and should i put them on the fronts or the backs? Also, where would a good place to go to have them put on the rims, will it cost a lot?
Matt
Old Apr 8, 2005 | 10:23 PM
Tom's Avatar
Tom
The 195/60R15s will physically fit, but don't bother. That tire is too small. It's over an inch less in diameter and your car won't handle right.
If you' put it on the front, the speedo will be off and the gap in the fender will look funny. If you put smaller tires on the rear, it really will look stupid.
Go here and do a comparison for yourself.
http://www.miata.net/garage/tirecalc.html
Old Apr 9, 2005 | 07:55 AM
subs1000w's Avatar
ive got those on the rear of mine and they work fine
Old Apr 9, 2005 | 10:38 AM
whitemax28's Avatar
yea plus the tranny will mess up.
Old Apr 9, 2005 | 10:56 AM
James92SE's Avatar
2 VE's are better than one!
Why would the tranny mess up...?
Old Apr 9, 2005 | 11:15 AM
subs1000w's Avatar
it could mess with the differencial if you have to different hight tires on the front
Old Apr 9, 2005 | 11:31 AM
RA030726's Avatar
I'm nutty for Nissans
nah thats only if the tires on the same axle are of differnt size.
Old Apr 9, 2005 | 07:29 PM
whitemax28's Avatar
exactly. you need all the tires to be one size
Old Apr 10, 2005 | 07:56 AM
Matt93SE's Avatar
STFU n00b!
WTF?!
The ONLY time that would cause damage to the differential is if you had different sized tires on the left and right FRONT wheels.
if both front tires are the same size, the diff will not have a problem. it doesn't care what size they are, as long as they're both spinning at the same speed when you're cruising down the highway. otherwise, it doesn't matter a damn bit what size tires you have on the rear, or if they even match at all.. as long as the front two tires are the same size, you're fine.
Old Apr 10, 2005 | 08:43 AM
Jeff92se's Avatar
I'm needing a caw
ABS system might not like it but I doubt our primitive system could give a crap.
Old Apr 10, 2005 | 11:23 AM
915spd's Avatar
you could use them, just for a temporary replacment. i'd recommend getting the stock size though.
Old Apr 10, 2005 | 03:57 PM
daltongc's Avatar
you'd be okay with them on the back, you're just pulling those anyway, so it really doesn't matter. They might look a little funny, but as close as the size is, you're probably the only one who's going to notice it. (except maybe another car nut) They'd be fine to run until you can get the right size. Might be a good time to think about some cool tires and wheels anyway if you've got to replace all four. The miata tire size calculator is priceless for determining what size to go to!
here's the link again: http://www.miata.net/garage/tirecalc.html
Old Apr 10, 2005 | 04:12 PM
slickblack94's Avatar
hi i was wanting to switch to 205/60/15 stock is 205/65/15 does anyone think this is to much of a difference? oh ya its a 94 se
Old Apr 10, 2005 | 06:32 PM
tripleGmax's Avatar
trade the saturn tires in on some stock maxima tires at your local place, they usually do that. atleast ive done it before.
Old Apr 10, 2005 | 06:43 PM
subs1000w's Avatar
no wont matter i had 205/50/15s on for a while now i have 225/50/15s
Old Apr 10, 2005 | 07:11 PM
daltongc's Avatar
slickblack, the tire size calculator will tell you exactly how much difference it will make. It will tell you what your speedo error is, plus or minus, and how many mph. check it out...
Mar 12, 2020 12:06 AM
Serotta33
Sep 17, 2015 12:14 PM
carid
Sep 9, 2015 05:06 AM
jfl330
Sep 4, 2015 01:44 PM
