results...
Old Apr 12, 2005 | 06:37 PM
blacks92seAuto
results...
results...no intake leaks, timing was about 15-16degrees, fuel PSI 35, no error codes on ecu, in emmission test it showed 150ppm HC at cruise.....and at idle it doubled...had 300ppm HC at idle.
Why would my car be putting out more HC at idle? and should I be at all worried?
Old Apr 12, 2005 | 06:57 PM
MrGone's Avatar
Here are mine
Old Apr 12, 2005 | 07:04 PM
blacks92seAuto
Originally Posted by MrGone
Here are mine
so basically I tied the cruise limit at 150 HC ppm and I fail the idle limit by 80 HC ppm....
What puts out more HC, or doesn't burn enough of it?...
should I adjust the IACC?
Old Apr 12, 2005 | 07:13 PM
MrGone's Avatar
Your in Washington right?
It's been a while since I've had to mess with emissions stuff. I think high HC would be the cat though, not completely sure on that.
Old Apr 12, 2005 | 07:30 PM
blacks92seAuto
ya in Tacoma.....I just had a cat put on from warpspeed when i got complete setup from them..so its only barely over a year old......maybe when my cousin did the emissions test, the car was barely warm.....i dont think he would of ran it for a long period of time...like as if i were to drive to emission place and then get it taken right away, so maybe the cat wasn't warm enough to do its job?
Old Apr 12, 2005 | 09:07 PM
MrGone's Avatar
I generally drive about 20-30 mins on the highway before going to take the test.
Funny thing was when I was getting it on the rollers I wasn't even thinking about what I was doing, stalled it twice
Old Apr 13, 2005 | 04:00 AM
Hectic's Avatar
just grab some of that additive that guarentees a pass. i've never used it so i can't say if it works or not but it's worth a try, you don't have to pay for tests untill you pass it so it might save you some headache. maybe you're running too rich. i had a civic with high hydrocarbon output and never past the test, but that's because the camshaft pulley busted off before i could try that additive, if it doesn't work you get your money back. or so they say. can't remember the brand, try thrifty auto if you have that up in tac.
my maxima just past last month with flying colors...not visible ones though of course
Gone: they let you guys operate your car for the test?? lucky man..
Old Apr 13, 2005 | 05:53 AM
blacks92seAuto
I had the emission test to see whts wrong with my car, not cover it up,...I want to fix the problem here..
maybe cleaning the egr valve?
Old Apr 13, 2005 | 08:19 AM
Hectic's Avatar
all i know is that the civic i had was running very rich and was rated very badly on the carbons so that could be the cause, unfortunately mr gone might be right which might be a little spendy don't know how much catalytic converters cost new but i doubt they're very cheap. do you burn oil? if so, that could cause it...especially at idle like you say. do a test after a new oil change see if it's any better.
Old Apr 13, 2005 | 11:20 AM
MrGone's Avatar
We drive it on the rollers, then the driver has to go stand in the 'magical safety box' and the tester then dyno's the car.
Old Apr 13, 2005 | 11:21 AM
MrGone's Avatar
Cleaning it never hurts, just making sure it works and all that, but I am pretty dang sure its your cat that is causing the problems.
Old Apr 13, 2005 | 11:33 AM
Jeff92se's Avatar
I'm needing a caw
EGR, PCV, plugs,coils,timing,cat,O2 sensor,coolant temp sensor,any other sensor etc.. all have an affect on emissions.
Old Apr 13, 2005 | 11:46 AM
blacks92seAuto
pcv valve is new, almost new plugs, timing is 15-16degrees, o2 sensor new tested=ok, coolant sensor tested=ok.....
I read on this website where if your cat isn't warmed up enough, it would put out up to 80% more HC than it would if it were completely heated up....My guess is, the car was only running for a short period of time when he tested it.
Old Apr 13, 2005 | 11:48 AM
Jeff92se's Avatar
I'm needing a caw
Then warm it up well and test again. 2nd test is free.
Old Apr 13, 2005 | 12:56 PM
MrGone's Avatar
HC = incomplete burn mainly. When it's cold the car runs pig rich, but the guys at the testing place should have said something.
Are all of your injectors are working properly?
Old Apr 13, 2005 | 01:43 PM
blacks92seAuto
it was at a shop.............I had him do a few other things that just running to the old emissions place won't do. so 2nd test isn't free =P....I know all 6 injectors ohm out properly...and when i put screwdriver to front 3 then to ear, the front 3 all sound the same and sound like they working. when i had my jdm motor put in...my mechanic used my original fuel rail from my old motor, which i think were good, didnt have problems with them.
i been listening to my car more carefully....and every 10-15seconds it will misfire once. cause i here my exhaust do a quick put...maybe its a bad coil pack misfiring?
i did a throttle body coolant bypass to hook my water temp gauge up a few months ago...mechanic said this could cause it to run a lil richer....I thought it was mainly so the plate wouldn't stick in really cold weather.
Old Apr 13, 2005 | 01:44 PM
Jeff92se's Avatar
I'm needing a caw
Well you should have 6 extra coil packs you can swap out.
Old Apr 13, 2005 | 01:47 PM
blacks92seAuto
unfortuneately the front 3 from the jdm motor were cracked, and 1 or the back ones is bad, i forget which one....I suppose i can do some swapping in and out with the back 3
what do they run, $60 a pop at autozone?
MaxStock
Aug 1, 2015 10:39 AM
Ghozt
148
Jun 5, 2013 09:18 PM
Mad-MAX_SE
1/4 and 1/8 Mile Racing
Dec 13, 2012 10:44 AM
fatboyslim86440
Nov 16, 2012 11:08 AM
WERNER1
Nov 27, 2010 06:55 PM
