How much does JWT advance the timing?
Old Apr 12, 2005 | 08:23 PM
5 ltr. beater's Avatar
I made a post last week but I can't find it. So here I am again posting the same question again. Thanx.
Old Apr 12, 2005 | 08:34 PM
Matt93SE's Avatar
STFU n00b!
stuff like that generally isn't known..
the ECU runs stock timing at idle/no load, so when you check it, you set it to stock timing.
once you fire up the engine and get it running is where it does its magic.. and you can't see that with a timing light.
Old Apr 12, 2005 | 08:40 PM
the reason I ask is because i was on Aaron's website and he had his timing advanced to 28' degrees and runs 100 octane. So i was thinking of advancing the timing on my car even more and running a little more octane in my gas. But before I can do that, i need to find out what JWT sets it at. Guess i'll have to call them in the morning.
Old Apr 12, 2005 | 09:01 PM
subs1000w's Avatar
honestly i dont think theyll tell you any of there changes made and proboly tell you not to mess with your base timing any more
Old Apr 12, 2005 | 09:12 PM
MrGone's Avatar
when you install the JWT you are supposed to set the car to the base 15*.
28* advance
Old Apr 12, 2005 | 09:22 PM
Aaron doesnt have a JWT ECU. He just advanced his. I was thinking of advancing mine along with the tune from the JWT ECU. Doesn't seem like a good idea though.
Old Apr 12, 2005 | 09:25 PM
MrGone's Avatar
I know, I was talking about the 28*
Old Apr 14, 2005 | 04:55 PM
eric93SE's Avatar
Originally Posted by Aaron92SE
What's wrong with 28 degrees? You can easily run 25 degrees on 93 octane if you keep your engine temps below 210. When I was tuning with my ZEMulator with the 300zx ECU, with 100 octane, I advanced the timing another 20 degrees above my previous knocking point with 93 octane. I could probably advance it to 35 degrees easily before it starts to even think about pinging with 100 octane fuel. Especially considering that I don't let my car ever get above 165 degrees at any given moment on the track. It's hard to hear detonation without a muffler and your cutout open at the track. So I decided to play it safe.
edit: chopped out my stupidity
edit: The JWT ECU is supposed to bump the timming 9* AFAIK.
Old Apr 14, 2005 | 05:21 PM
MrGone's Avatar
Originally Posted by eric93SE
Aaron, advancing the timming is supposed to give a lower timming number not a higher one, advancing is igniting the mixture sooner not later. Its been a while since I've check my base timming, but now I don't have timming marks on my prototype UDP to check the timming. I have my CPS marked for stock timming and four degrees advanced (11* BTDC).
That would be retarding it. Aaron has his set to ignite 28* before top dead center. Stock is 15, most people run 18-20. Actually I think you said you have yours at 18 a long time ago and couldn't feel a difference between 18 and 20*.
28* is crazy. If I ran almost 15* of advance on my mustang it would run like crap and probably detonate to hell(I use that as an example because there is no ECU to pull back the timing or to adjust the advance maps). The ECU has to be pulling some back. There is fine tuning, but there is a limit. Think about how far away the piston is from TDC at 28*.
Old Apr 14, 2005 | 05:25 PM
eric93SE's Avatar
Whoops, your right. Had to read a little and straighten myself out
sorry
Old Apr 14, 2005 | 05:26 PM
MrGone's Avatar
sorry
You got me on VTC's, I had to get you on Ignition. It's only fair
Old Apr 17, 2005 | 11:40 PM
Jeff92se's Avatar
I'm needing a caw
I'm not sure if you will ever get that specific info. I suppose if Aaron had the maps somehow or if you hooked up the consult and read the ign maps you might get it. But don't count on JWT giving you the info.
It's not just the base timing. It's the timing curve. Just advancing the base timing will of course advance the timing curve also. The JWT unit might advance and then retard the ign curves depending on what they tuned it to. Something just advancing the base won't do.
I suppose you could play around with it. But IMHO running such high octane might not be that great for everyday driving. Maybe for a track only setup. If you want to do some real tuning, try getting a SAFC and a Wideband 02 and play with that. Or spend some time on the dyno with the wideband and see what you can get out of it. If the ign curves are okay except for a few points in the rpm curve, you might be able to richen those specific points up and supress the knock and still run a good a/f and timing everywhere else.
Anything else is just a crapshoot.
Matt93SE
May 24, 2019 02:58 PM
Starrider
Sep 17, 2015 07:26 AM
305head
Aug 26, 2015 09:03 PM
t6378tp
Aug 24, 2015 07:03 AM
3rdmaxse0
Aug 18, 2015 08:25 AM
