transmission question
Old Apr 15, 2005 | 08:20 PM
furious max's Avatar
Ok guys I know that this topic has been talked about many times. I've even asked once but forgot. I've even searched but can't get what i'm looking for. Here goes, Can I mount a vg trans to a ve engine. I have a vg trans and my ve trans is shot. Would it bolt up? Whats the difference. Or do I have to buy a ve trans. Don't kill me on this. If theres a post in the search can someone tell me whats the write up to that post so i can check it out. I've tried many different ways of gettin the info but again can't get anything. thanks...
Old Apr 15, 2005 | 10:25 PM
Michael's Avatar
Back in a 3rd Gen.
well I assume since people have done the opposite then you can do what you want. I know some that have put the VE trans on the VG.
You will have to change the hub because it uses a different spline than the VG and also different axles...other than that I dont know.
Old Apr 16, 2005 | 05:19 AM
Now would that be a problem because of the more power the the ve has that the the vg trans would get messed up? Can you tell me whats a spline?
Old Apr 16, 2005 | 07:13 AM
Michael's Avatar
Back in a 3rd Gen.
I dont know...probably wouldn't be a problem but I am not sure how strong the VG 5 speeds are. I know I wouldn't do it. The VE has VLSD which is a plus and is a stronger transmission I think.
as far as spline goes...Here is a helpful link you should use for words you dont know.
spline
1.
a. Any of a series of projections on a shaft that fit into slots on a corresponding shaft, enabling both to rotate together.
b. The groove or slot for such a projection.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
I<3 A32's
Sep 10, 2015 11:07 AM
videomano
Sep 8, 2015 03:28 PM
