Great Deal so i bought it, But...
Old Apr 20, 2005 | 01:22 PM
lalo's Avatar
So a Around November (i think) I purchased a Used VG from pick a part, one of their locations was closing and everithing was on sale for a $1. I purchased the engine and it has been sitting in storage for a long time now.
I have not even looked at the engine, never checked if it ran but thought I might need a spare and I could not beat the price. My current engine is running strong at 160,000 so im in no hurry to fix this thing, just wanted to know how much should I espect to pay to have this thing back to STOCK performance. (asuming I would need to replace all gaskets, pistons, ect...) (also asuming the block/head are not damged). basicaly would it even be worth it, or could I get a running low milage engine for less than what it would cost for me to rebuilt the junkyard engine? Any opinions, coments are greatly apreciated.
Old Apr 20, 2005 | 02:35 PM
mtnbikeair's Avatar
You could probably get a reliable running engine for around 400 if you looked i bet, and getting it rebuilt would definitely be more, saying that just the headgaskets alone are up at like 200.
Old Apr 20, 2005 | 02:42 PM
CyMax's Avatar
UUUUUMMMM reliable mabye, but remanu ( like stock ) no Remanufactured.com nissan engine lists a VE30DE at 2590.
Old Apr 20, 2005 | 03:12 PM
lalo's Avatar
$2,600 for a reman engine, it has to be cheaper to re-build. The Engine was $1, so even if I spend $600-$700 (I Think) to rebuild, the Junkyard engine would have new everithing and come out cheaper.
Has any Rebuilt the VG on their own? is my estimate ok?
EDIT: then again $400 for an OK engine is not bad at all, and it would leave me @ the point im at now. Besides I dont race the car, its my daily driver so used engine would be fine I guess.
Old Apr 20, 2005 | 07:25 PM
CyMax's Avatar
Sorry my bustI listed the wrong engine a VG30DE lists at 2490. Guess I should read better, either way I think it would be cheaper (IF ONE DID THEIR OWN WORK) to rebuild.
Old Apr 20, 2005 | 08:11 PM
mtnbikeair's Avatar
If you can do the work, it would probably be a fun project, but i am in need of a new engine for my car, and unless you really know what the engine has been thru, i would just replace it when the time comes. My headgasket is bad and i am just replacing the engine.
Old Apr 20, 2005 | 11:01 PM
Maxpwer's Avatar
No turbo, no care!
LALO,
The cost to rebuild varies greatly on what you replace. You mentioned pistons, which alone cost $400 from the dealer. If your pistons were bad (I doubt it) I would just go pick up a used running VG for (which can be found for $400 or less). But assuming everything is in good shape, heres what parts you should replace and their respective cost (based on what ive paid through courtesy nissan).
Piston rings/rod bearings/crank bearings -$75
Front and rear main seals $50
Timing belt/tensioner/waterpump/thermostat ~$200
Gaskets $350
Knock sensor $175
Exhaust manifold studs $50
There maybe other parts that need replacement but this is the minimum (IMO, and from what I can think of off the top of my head) that should be replaced during the rebuild. Internetautomart has most of these parts much cheaper than the dealer
Matt93SE
Apr 8, 2018 09:23 AM
incubusjohnny
Nov 3, 2015 05:18 PM
95Maxi
35
Sep 2, 2015 10:37 AM
doobadoo
Aug 15, 2015 06:43 PM
