Wheel Studs
Old Apr 25, 2005 | 01:07 PM
OBEEWON's Avatar
Wheel Studs
I've been looking for a while but I dont see any answers. In order to change a stud does the hub have to come off? Basically is there a way to change a stud without taking the hub off?
Old Apr 25, 2005 | 01:53 PM
Mizeree_X's Avatar
Getting back to his roots
In the front, yes. In the rear, I don't think so but taking the rear hub off is like 1 step so who cares anyway. In the front take a pair of tin snips and cut out a section on the rotor dust shield. You'll be able to slide the studs in and out through there. Here is a pic from my cardomain:
See where the stud at 1 o'clock is? That's where you cut a little section out and install / remove the studs from.
Old Apr 25, 2005 | 02:07 PM
OBEEWON's Avatar
Thanx man. I wanted to make sure this was safe before i went chopin away and had to buy a new spindle.
Old May 3, 2005 | 11:44 AM
OBEEWON's Avatar
I cant seem to get the stud out. Shouldn't it come out with a few bangs from a hammer? Ive sprayed WD-40 and it still wont budge.
Old May 3, 2005 | 01:35 PM
Mizeree_X's Avatar
Is your hammer a small sledgehammer? That's what I used.
Old May 3, 2005 | 03:55 PM
OBEEWON's Avatar
Yeah I think Im being a little soft on them. Dont want to bust anything. How much are those NISMO studs, and where did you get them. Ive been thinking of getting some.
Old May 3, 2005 | 06:28 PM
Mizeree_X's Avatar
They are $60 for a set of 10, and I bought them at Courtesy. Only get them if you need them, as they are $$$ compared to stock ones ($1 each).
Old May 4, 2005 | 11:46 AM
ChrisCheezer's Avatar
i can press in 5 studs in 2 min with my impact gun.
-air tools make everything super easy and much quicker. (best investment ever..)
-one super hard hit with a sledge will knock the old stud out..
Old May 4, 2005 | 05:22 PM
ItsNoMaxima's Avatar
If at all possible, use a machine press to pop the studs out. A hammer, especially a sledge hammer, can ruin wheel bearings.
Old May 4, 2005 | 07:46 PM
if u can knock the stud with one hit then all the force will be absorbed by the stud.. nothing will happen to the wheel bearings
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
