Master switch problem
Old Apr 27, 2005 | 04:39 PM
Brendan's Avatar
what's the deal with my master switch only being able to make mywindows go down and when i try to put them up they keep going down ever more, i took the switch off and went over all it, all connections seem to be touching, whats the dillyo?
Old Apr 27, 2005 | 07:43 PM
internetautomar's Avatar
mod or sell?
did you check the window regulators?
Old Apr 28, 2005 | 07:13 AM
RandS's Avatar
I have a similar problem with my 93 (RHD) model. When I switch on the master switch the front passenger and rear drivers side go down. Put the rear one up and it stays there until I put the front up then the back goes down!
The drivers and rear passenger ones are fine.
Help!!!!
Richard
Old Apr 28, 2005 | 08:46 AM
Wiking's Avatar
Help!!!!
Richard
The doors are logic controlled, NOT hard wired T-Ford -type. Each door has its own logic printed circuit board (PCB).
Push a button: Driver door sends now logic signal and simultaneously delivers +12V to the designated door. Logic signal defines [in the door PCB] which way the win reg moves...
The logic signals are really weak, and operate at 0-5V levels. (STUPID! arrangement...) Thereby moisture and/or bad connections can easily make whatever...
I suggest u look for moisture, then spray cleaner on contacts, add contact grease on EVERY pin, every door...
Seek for schemas (if available) at bottom of page http://www.cardomain.com/memberpage/748507/1
Smtg bits on the door electronics is at: http://www.cardomain.com/memberpage/748507/13
Edit:
Note the transmitter (drivers door) data line to receivers... Look also for healthy +12V and grounding connection.
Old Apr 28, 2005 | 09:35 AM
adroga's Avatar
can a bad master switch usually be fixed by cleaning the contacts and adding contact grease?
Mine either works fine.. or doesnt work at all for about 5 minutes of pressing the up button. This would be for the 1 window out of 4 that I have that doesnt have a broken window regulator...
Can the regulator be removed and rebuilt in any way?
Wilking.. your site is awesome and I am planning on using it for quite a few repairs I need to do..
Old Apr 28, 2005 | 10:02 AM
Wiking's Avatar
Originally Posted by adroga
can a bad master switch ...
...be fixed by cleaning the contacts and adding contact grease?
- intermittent bad contact problems in any electronics pins may be corrected with contact grease. The problem is, that too much of it will cause a undesired short... So apply it with a toothpick. Generally I dont suggest u use on computers with tightly packed pins, but in cars the corrosive environment is another issue: My ABS started to work like dream after adding CG on each connector pin in the trunk ABS box.
- Maybe its time for 'new' master switch box from junkyard? The problem is, probably theyre already going bad... ask internetautomator ?
...broken window regulator... Can the regulator be removed and rebuilt in any way?
- theyre quite cheap there, better ask internetautomator for a new one... I have rebuilt RH regulator to LH door on my former nissan, but thats because the reg costs here some 400$! Just dont do it, rather go surfing...
Old Apr 28, 2005 | 10:05 AM
adroga's Avatar
thanks wilking...
Old Apr 28, 2005 | 04:02 PM
Brendan's Avatar
great info, thanks man
t6378tp
Sep 29, 2018 04:27 PM
rnb754
Sep 14, 2015 11:39 PM
Maxie40
Sep 14, 2015 11:28 AM
