low rpm at idle
Old May 12, 2001 | 07:46 AM
atulb84's Avatar
how can i raise my rpm at idle . its at like 300 with no a/c and a turn signal. please help. i'm not very car smart so please explain detailed
Old May 12, 2001 | 09:41 PM
superdesi's Avatar
Yeah. And its quite simple. All you do is turn a screw located near the TB.
Old May 13, 2001 | 05:55 AM
maximusSE's Avatar
Low rpm during breaking?
does anyone know why my rpms would drop below idle during breaking? it doesnt do it all the time, but sometimes at night it will make the light go dim for a sec and then back to normal any ideas?/?
Old May 13, 2001 | 02:39 PM
MadMaxBrent's Avatar
Not quite
Before you adjust the TB screw you need to close the AAC valve otherwise you are not correctly setting the idle. To close the AAC valve you need to turn the diagnostic screw on the ECU to the diagnostic mode (Do a search on this forum for where the ECU is located etc) then you can adjust the idle via the TB screw. Once you have it set right, then turn the ECU screw back to where it was.
Brent
Old May 13, 2001 | 07:43 PM
brubenstein's Avatar
Before setting the base idle speed, make sure the throttle body is clean. The idle speed has dropped over time because the TB is dirty. Adjusting the screw lets more air in, but there is a limit to how much the AAC can flow to compensate for extra load on the engine and a dirty TB.
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
