try to seal my trunk
Old May 3, 2005 | 01:17 PM
kado100's Avatar
I try to seal my trunk but it still rattle when I turn up my music. Any suggestion on what kind of products should i use.
Old May 3, 2005 | 01:35 PM
Matt93SE's Avatar
STFU n00b!
turn down the stereo.
look for rattles, not leaks.
wire harnesses need to be taped to metal surfaces. license plate and frames need to be firmly bolted on all 4 corners, not just two. a piece of foam behind it doesn't hurt either.
remove the vent at the bottom of the trunk as well. they make noise..
and lots and lots of dynamat!
Old May 4, 2005 | 09:45 AM
kado100's Avatar
thank you I'll try it
Old May 4, 2005 | 12:55 PM
pito11213's Avatar
Dynamat is a beautiful thing but not too much or you will just be adding weight. That is if you care about that. The max is a very good car to put a system in.
Old May 5, 2005 | 06:28 AM
DaWifey's90's Avatar
what can my max do for me
any opinions on their spray vs the sheets? used the spray inside the dorrs of my bronco and seems to work great...just can't imagine having used a sheet in there...
lighter too - well, depending on how many coats you put
Old May 6, 2005 | 12:41 PM
StylinzMax's Avatar
dynamat is good it gives the perfect seal make sure you get it done professional or if you someone that can do it for it thats good too
Old May 6, 2005 | 01:03 PM
MrSector9's Avatar
I have read that the spray on deadener can be twice as effective if used at the same thickness as the mat style brands.The prep time is more but overall it is a faster neater looking job.Spray is asy to get in places you cannot normamly reach.
I used both mat style deadener and spray on the doors of my maxima.
Old May 6, 2005 | 05:52 PM
molehill84's Avatar
Peel & Seal is the way to go...
Old May 7, 2005 | 06:07 AM
swowlinc's Avatar
1993 SE
Take off your center taillight piece and put dynamat on the trunk lid just behind it. Took away most of my rattle.
REDinLV
Aug 15, 2024 12:30 AM
James92SE
142
Jan 2, 2024 09:23 AM
mpbclutch33
Dec 26, 2015 11:11 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
