bad vibrations
Old May 4, 2005 | 09:59 AM
4thgradedropout's Avatar
bad vibrations
ok so recently ive noticed that whiel im at a light stop sign ect....my car shakes like crazey and is at about 500 rpm some times it will chug rally bad so the steering wheel moves?....any ideas?
Old May 4, 2005 | 10:00 AM
typo while****and really***geesh need to review before i post
Old May 4, 2005 | 10:16 AM
Wiking's Avatar
What have u done with u max? I guess nothin but miles...? Btw. Did u know tommy franks [best general in history] is also a hs dropout?
--->pls look down: http://forums.maxima.org/showthread.php?t=401368
Old May 4, 2005 | 10:18 AM
kcidmil's Avatar
Ewww... sounds like a bad injector or 3.
Old May 4, 2005 | 10:38 AM
generation3's Avatar
I had that problem I replaced the spark plug wires, distribution cap, and got a intake system cleaning. It could be a lot of problems though luckily I didn't have to replace my O2 sensor.
Old May 4, 2005 | 10:41 AM
i got new spark plugs new wires new cap and rotar. the only mods i have done is the honda accord intake how much are injectors?
Old May 4, 2005 | 10:47 AM
Wiking's Avatar
mtcookson said he bought two new leaking caps in a row... I just repaired mine which had 10kmiles. Make sure u have no cracks.
Air leak can also cause this; rubber hoses play intermittents nicely.
...the honda on this forum sounds dAngerOus.
Old May 4, 2005 | 11:07 AM
hadman's Avatar
Oh Lucy...somebody has some essplainin to do....
Old May 4, 2005 | 11:20 AM
DARHAW-MAX's Avatar
Honda Accord Intake? Enlighten.
Old May 4, 2005 | 11:36 AM
a cold air intake from a 93 honda accord will fit a maxima as a short air cai however it is .5 inches smaller in curcumfrence then the stock one but it does not make a noticible diference.. also you have to modify some hoses in what ever fasion you choose
Old May 4, 2005 | 11:43 AM
Wiking's Avatar
... it is .5 inches smaller in curcumfrence then the stock one but ...
.5 inch choke makes rEal difference, at least 20% smaller area.
edit:
This sausage has two ends:
- choked, longer intake, better torq, (feels like more 'pwr' at low rpm)
- opened intake, more pwr at upper rpm, less torq
Old May 4, 2005 | 12:01 PM
DARHAW-MAX's Avatar
Okie dokie. Now I know. Thanks. That is the first that I have read that--at least from what I remember (Time for my Focus Factor)
Old May 4, 2005 | 05:04 PM
ItsNoMaxima's Avatar
My advice would be to search for a vacuum leak. Use a cheap carb cleaner and spray around the vacuum lines and especially that intake that is too small for the Maxima (Because it's from a dirty Honda) If the engine idle changes up or down, there is a vacuum leak that needs to be repaired
user 11122324
42
Jul 18, 2022 03:35 PM
chisam14
Nov 6, 2018 08:56 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
RealityCheck
Oct 2, 2015 06:34 PM
Andy29
Sep 29, 2015 05:32 AM
