Tranny Cooler for everyone to see
Old May 13, 2001 | 11:28 AM
lcali1's Avatar
I just installed my tranny cooler a couple of days ago, N decided to place a pic of it since the topic has been asked on the board lately. Made by Hayden, model 403 for $38 at Pepboys or local auto part store. Sorry about the attachment.
Old May 13, 2001 | 01:23 PM
CandiMan's Avatar
Say Candyman 5 times
Great
I just pick up the same model cooler and was wondering if there might be a clearance problem. It's tight, but it does fit. My original cooler was clogged after my tranny self destroyed.
Old May 13, 2001 | 05:59 PM
Evil Yak's Avatar
Do any of you guys bypass the stock cooler
when you upgrade, or do you run the line from the stock
cooler to the aftermarket one?
Old May 13, 2001 | 07:28 PM
mymax93's Avatar
how hard is it to get that thing in and will pep boys do it for u? how much do u think labor is?
Old May 13, 2001 | 09:12 PM
lil_Jay22's Avatar
does this mod have any positive effect in performance??
if so is it difficult to install?
Old May 13, 2001 | 09:36 PM
lcali1's Avatar
Combo
No, do not bypass anything. Both stock and aftermarket cooler will work together cooling your tranny fluid. Hence like a combo cooling. As for effects well it'll save the life of your tranny about 30% longer, and your shifting will be alot smoother. You'll also feel quicker acceleration at higher speeds. The job is fairly E Z and I could'nt tell ya what your local auto store would charge ya for install but Im pretty sure u have a friend that could help ya with it...save u $$$ like that.
Old May 14, 2001 | 02:47 PM
CandiMan's Avatar
Make sure
The ATF flows from the tranny to the OEM/radiator cooler then to the after-market cooler and back to the tranny.
Old May 14, 2001 | 06:49 PM
lcali1's Avatar
Re: Make sure
Said no better than CandiMan . Exactly how it works.....
Old May 15, 2001 | 11:57 AM
speednsound007's Avatar
is there a writeup for the install?
How long did it take you?
~PJ
Old May 16, 2001 | 07:10 PM
bump
Old May 17, 2001 | 01:11 PM
Matt93SE's Avatar
STFU n00b!
instructions come with the cooler. it takes about an hour, less if you've done one before.
Old May 24, 2001 | 02:31 PM
Cincy94Max's Avatar
Did you need to buy anything besides the cooler itself. I have read a couple how-to write-ups that say you need 4 feet of transmission line, but that was for a 4th gen. Did you need this hose or anything else? Also, what all on the car did you have to remove/move?
Old May 24, 2001 | 02:52 PM
93 SE's Avatar
i did this couple days ago,bought hayden 403,it didnt come with hose kit for me,i had to buy it separate,fyi i bought cooler & kit at pepboys,this dyi for me was a pain,simply cuz my grill would not come off,and i was to scared to force it off,cuz it woulda cracked,then i would have buy new grill n do mesh over again,all in all if you can get your grill off it would be easy,its all self explanatory
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
catalinvint
Sep 16, 2015 07:48 PM
pktaske
Sep 4, 2015 08:40 AM
