my fuel injector wires are cracked and broken, how do I stop the hesitation??
Old May 13, 2001 | 12:29 PM
AKAICEBERG's Avatar
Hey Fellas, Last night I noticed that my car would hesitate and almost stall. It only happened a couple of times coming to a stop, but it was enough to worry me. Anyway, I check under the hood today and I noticed that when I went to touch one of the injector wires the car started to struggle and hesitate. BINGO, found the problem. It seems as that my injector wires have cracked all the way around exposing the wires underneath. I put some electrical tape around them and things where working fine untill tonight when it hestiated badly. How do I fix this problem? I sure hope there is a cheap fix because I really don't want to spend any more $$ on my max.
Please help,
Kevin
Old May 13, 2001 | 08:42 PM
1991gxe
fuel injector harness
hey what u first need to do is go to your local auto store and buy whats called electircal cleaner. this item iten cleans the contact in the harness. next step is to remove the harness form the fuel injectors. spray some of the cleaner in them and let it absorb in it. this will clean the corrosion.use a small flat head screwdriver to get into the contacts. once your done but the harness back in and u shouldn't have anymore hesatation. the reason for your problem is that thru out time corrsion builds up. you will notice a green type color when u take out the harness. let me know what happens.
The Frye
Sep 2, 2021 11:03 AM
cruce91
Sep 20, 2015 10:23 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
trungg86
Sep 4, 2015 04:58 AM
Balkins
Aug 12, 2015 06:39 AM
