Changed T-belt - now running rough...
Old May 19, 2005 | 03:56 PM
RyderMax's Avatar
What a way to spend a vacation ...
Had the timing belt, tensioner, water pump, cam and crank seals changed on the Maxima. Job was finished, and the car ran fine.
Later that day, engine started missing. Took it back to mech's this morning - running rougher and rougher. Checked, and changed plugs, rotor, dist cap (boy - how did it *ever* run with that thing in place?), and finally plug wires. Ran fine for 2 mins, then started running rough again.
Stopped the car - came back 5 mins later - she's running smooth as a baby's bottom. Driving around, went over some RR tracks - starts running rough again. Stopped, did an errand, came back, car's running fine again - and continues for about 30 mins, with a couple of stops on the way.
On the way home, went over some bumps, and she's rough again...
I'm thinking something electrical is loose or broken - maybe injector wiring? maybe a ground? I was thinking that the belt slipped a tooth earlier, but that doesn't explain why it ran smoothly later...
Ideas?
Michael
Old May 19, 2005 | 04:28 PM
internetautomar's Avatar
mod or sell?
I'd start by going back and checking that everything is torqued to spec and all connectors are on tight.
but your problem does sound electrical in nature, it's gonna take lotsa time to diagnose though, unless you just wanna throw parts at it
Old May 19, 2005 | 06:29 PM
VEvolution's Avatar
I miss my VE
does everything need to be torqued to specs like the FSM says, or can you let it slide on most things? its just i find it nearly impossible to get that damn torque wrench in tight spots.
Old May 19, 2005 | 07:05 PM
Drivin Maxima's Avatar
Im thinkin electrical also. I would start by checkin all the electrical connections and grounds that are around the area where the work was performed. Maybe a coolant temp sensor wire was hit and weakened, or a coil wire, or something of that nature. Good luck
Old May 19, 2005 | 07:56 PM
jigga123's Avatar
I had dat problem to, when I thoght the belt was tight the tensioner wasnt keeping it in place and everytime I went to start it, it would idle rough and the timing would jump. If you wanna do a quick check to see if the timing is out, advance it slightly at the distributor and see if it gets better. If it does, take it all down and redo it.
Old May 20, 2005 | 01:06 PM
RyderMax's Avatar
Well, it appears that the middle injector on the back bank is pooched. 0.0 ohms resistance isn't a good thing, is it? Funny how it would work and then not work, though...
Old May 22, 2005 | 10:31 AM
mod or sell?
i had one of my injectors do that to me a few times.
there is hope that it may start working again by itself, but be prepared to eventually replace it when it decides to fail for good.
also when you do replace it, I HIGHLY recommend replacing all 6 with new ones, the rebuilts have a very spotty track record.
Old May 22, 2005 | 07:15 PM
Morgan's Avatar
Do the tensioners get noisy, like a bad lifter when they start going out? Or do they just strand you?
Old May 22, 2005 | 07:16 PM
Morgan's Avatar
Should have added, the car is a 94 with 190000miles runs strong, just noisy over the last week.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
