intake adapter
Old May 22, 2005 | 08:11 AM
3rdgene's Avatar
intake adapter
im gonna put on a 93 accord short ram on and need a maf adapter, but dont want a filter that comes with it on ebay... Anyone know where i can just by a maf adapter???
Old May 22, 2005 | 08:25 AM
disgruntled's Avatar
matt (blehmco) makes them, for 25 bucks a pop, but as of current, he states that he is busy with his family, so he will get back to me on that subject matter. I also bought two MAF adapters from ebay, one is a direct fit, and when purchased, is only the adapter alone. The downside? its made out of plastic. The other MAF adapter I had is made out of aluminum, but is not a direct fit, and must be frankensteined to work. Do a search on ebay under 300zx maf adapters, they will fit as well, and a BIG HINT for you, make sure that you know the shape of the MAF sensor opening before buying the adapter, or you will be in for a big disappointment.
Old May 22, 2005 | 08:31 AM
3rdgene's Avatar
for 25 bucks i can get the correct maf adapter and a filter on ebay.....was just hoping for the adapter. Oh well thanks for the sensor warning.
Old May 22, 2005 | 09:09 AM
you can also make one yourself, forgot to tell you about that. Just need a length of 3" pvc pipe, a piece of high tensile plastic ( like one you can chop from your stock air box), and some pipe glue. Also, there is a metal piece inside of the air box that will work as an adapter, you just need to have access to an exhaust pipe cutting tool, and cut the flange off (you'll see what I mean when you open it up. Good luck by the way.
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
