Is this the dreded window reg????
Old May 22, 2005 | 12:06 PM
CyMax's Avatar
Ok so after slamming the drivers side door last night ( don't ask ) the window won't do anything. So I fogured it's the dreded window reg. Well today I get the door panel off and see that the cable that lifts the window is off it's plastic guide, pulley thing. I've tried to put the cable back on track and now it seems that the cable on the reg is bunched up, or twisted or something, cant really tell, it just makes noise and moves like an inch. So tell me if I'm wrong or right, am I going to be replacing a window regulator next weekend??
Thanks everyone!
Old May 22, 2005 | 12:13 PM
nelledge's Avatar
"I'm just sayin'..."
Originally Posted by CyMax
I get the door panel off and see that the cable that lifts the window is off it's plastic guide, pulley thing. I've tried to put the cable back on track and now it seems that the cable on the reg is bunched up, or twisted or something, cant really tell, it just makes noise and moves like an inch. Am I going to be replacing a window regulator next weekend??
Looks like you're right unless you can find a way to rebuild it. Little patience, some know-how, and spare parts. That won't guarantee the worn cable won't bind again, but it's up to you. Me personally? I would replace it.
Old May 22, 2005 | 12:16 PM
Wiking's Avatar
....am I going to be replacing a window regulator next weekend??
Depends on the weekend:
- snow heights
- interest rates
- wire flakes
Might be able to rescue it, really depends on wire condition. I have changed the wire once; with u low prices not worth it. Hmm. This is the way how I learn to close doors...
Old May 22, 2005 | 02:14 PM
bhunter's Avatar
To really repair it properly it should come out. If you're going to go that far, put in a new one. It really seems to be a no-brainer unless you are one of these totally broke kids.
Old May 22, 2005 | 06:27 PM
CyMax's Avatar
Your right, as long as I'm there..... Internet Automart sells the regulator for 40$ + shipping. So, ya a new one will be on the way as soon as the Fiancee let's me drop the $$. Thanks for the help.
Old May 22, 2005 | 07:33 PM
erty67's Avatar
Decal Specialist
Sounds like my pass side window. I replaced the regulator today. It's a fairly easy swap.
Old May 23, 2005 | 07:13 AM
LMaRiE91MaXiMa's Avatar
Thanks everyone!
Yep, sounds like the regulator to me! And i dont know for sure, but I heard its a pain in the *** tryna fix them (if its even possible) so youd probably be better off buyin a new one for $30 and spending the 10-15 minutes it takes to replace it on your own. If you need a new motor as well, your probably looking at $40-$50 as opposed to $30
Old May 23, 2005 | 10:53 AM
dtahsee's Avatar
It definitely is the regulator. I had the same problem with my passenger side window. The wire jumped its track. I tried to push it back in but the wire kept bunching up. Had to replace the regulator. It cost me $70 for the regulator, but that was a while back and it was a dealership. I think prices might have come down since then. Luckily it seems that your motor is fine. You can get instructions to replace the regulator at www.4dsc.com, but dont think you'll need them.
Old May 23, 2005 | 12:49 PM
Cliff Clavin's Avatar
Way out West
Craig has a write up on his site in the stickies.
The first time, it took me a while, but the second one I replaced went quickly. It is a pretty easy job. Just put in a new regulator and be done with it. Don't bother trying to fix it because those plastic pulleys will just break and you will be mad you spent all of the time trying.
Oh, and I wouldn't call a window regulator "dreaded." It's a cheap, easy repair that is just a minor inconvenience while you wait for the new one.
VTC replacement or transmission replacement would be "dreaded."
Old May 23, 2005 | 03:08 PM
CyMax's Avatar
Your right there mabye I should have said notorious POS. Thanks for the tips all!
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
Luev
Sep 30, 2015 11:50 PM
