Speedo is not working
Old May 22, 2005 | 08:01 PM
aw89maxSE's Avatar
Just started happening the other day. Sometimes it will work and sometimes it won't. It seems as when it's not working, it will jump back up to my speed if I hit a bump or going about 50mph+. Pretty annoying and I want to fix it. Help me out guys
Old May 22, 2005 | 08:05 PM
Drivin Maxima's Avatar
If its an automagic then there is a module thingy on top of the tranny (under the intake resonator). check that for loose connections or dirt/corrosion. If its manual then there should be a harness that comes up from the bottom of the tranny and plugs into the engine harness. Check that for loosness or corrosion also. Good Luck
Old May 22, 2005 | 08:33 PM
aw89maxSE's Avatar
Yeah it's an automatic
Old May 22, 2005 | 11:25 PM
Wiking's Avatar
Theres the sender in tranny. Broken? Wire loose, or the gauge assy or gauge...
The sender can be tested. click http://www.cardomain.com/memberpage/748507/15 and see also page1 links.
Old May 23, 2005 | 08:29 AM
Will's Avatar
It is likely a bad speed sensor or the speedo circuit board is bad.
Old May 23, 2005 | 08:33 AM
hadman's Avatar
I would agree with it likely being a speed sensor.
Old May 23, 2005 | 10:33 AM
Maximum Depth's Avatar
Before replacing any parts, check out my instructions on fixing a loose VSS connection. I had the exact same symptoms, and it fixed mine. http://forums.maxima.org/showthread.php?t=400362
Old May 24, 2005 | 09:24 AM
aw89maxSE's Avatar
I figured out that it goes off when I hit a bump and then it goes back on when I hit a bump.....gotta be a loose connection somewhere. Gotta check out that VSS things
Old May 24, 2005 | 09:37 AM
internetautomar's Avatar
mod or sell?
the top part of the VSS pops out sometimes. just push it back in
Wiking's Avatar
Do that first, the print out the speedo schema (see how -my previous msg) and redline the connections and then check/find everyone, clean. I would start the cleanup from ECU/TCU connectors:
http://www.cardomain.com/memberpage/748507/14
Old May 26, 2005 | 01:31 PM
aw89maxSE's Avatar
Seems to be working so far
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
