light shuddering
Old May 25, 2005 | 05:51 AM
Aggressor's Avatar
light shuddering
my max has been shuddering at low rpms when cold lately... not badly, just enough to let you know that something is amiss... Any ideas?
Old May 25, 2005 | 06:48 AM
Wiking's Avatar
Originally Posted by Aggressor
... Any ideas?
idee1: Tuneup time.
idee2: TPS acting, see wHere ↓
idee3: Connector Cleanup Time
1. Plugs wires cap http://www.cardomain.com/memberpage/748507/12
2. http://www.cardomain.com/memberpage/748507/6
3. http://www.cardomain.com/memberpage/748507/14 etc.
Old May 25, 2005 | 09:49 AM
Aggressor's Avatar
Just did a tuneup...
I'll check the TPS and grounding this weekend. Thanx!
Old May 25, 2005 | 12:01 PM
Wiking's Avatar
Note: Mtcookson said he bought TWO new caps in a row, both dead =leaking!!! These plastics caps =craps. Mine lasted 10k and then sputtering again. Sprayed lacquer and now about ok.
Old May 26, 2005 | 09:58 AM
Aggressor's Avatar
Just curious... why does it only happen when its cold?
Old May 26, 2005 | 10:44 AM
Wiking's Avatar
Why does what?
TPS?
COLD: TPS input (throttle opening) defines how ECU adjusts the engine based on best guess. After coolant temp sensor resistance drops, indicating warm engine, O2 will be used instead. O2 in the exhaust gives exact feedback how the ignition/injection actually succeeded. O2 sensor needs high temp to function. MAF gives all the time info of air qty (mass).
CracEd CAP?
Moisture in cracks, after warmup evaporates. Hot/Dry=bad conductor, Cold/Moist=good conductor; sparks go whereever but plugs.
Old May 27, 2005 | 05:41 AM
Aggressor's Avatar
Clear. Thanx!
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
