Are The E36 Lights Easy To Install
Old May 27, 2005 | 07:12 AM
nForce's Avatar
The Computer Guy
Internetautomart has a pair of E36 Hella for $150, Will those just pop in place of the stock ones? Also will the wires be able to be hooked up or do they need some moding?
Old May 27, 2005 | 08:33 AM
5 ltr. beater's Avatar
I think I speak on behalf of almost all the Org. memebers by saying that it is definetely not a direct swap. Lots of cutting and grinding is necessary. I'm getting ready to do it myself; but I'm waiting for an SoCal org. member to help me out. I should have some help sometime next year.
Old May 27, 2005 | 08:50 AM
3rdgene's Avatar
it is fairly easy just really time consuming. There really isnt a right or wrong way since it is custom... it will sit alittle behind the grill but it still looks good...if you need any details let me know.
Old May 27, 2005 | 09:32 AM
mtnbikeair's Avatar
You will have to buy new wiring harnesses that will be able to use the two bulb lights instead of the one bulb high/regular beam set. As for making the lights fit they wont just "drop" into place, you will have to do your fair share of cutting and munipulating to make them work, but its not a project that you cant do. I didnt think it was too hard to make them fit, you just have to take your time and see where the light hits the bracket and just figure out the best way to make everything fit. Good luck.
Old May 27, 2005 | 09:51 AM
tripleGmax's Avatar
seriously just search and youll find the writeup. its not hard, just took me some time. www.geocities.com/craigbrace/ has links to both the writeups.
Old May 27, 2005 | 01:14 PM
CyMax's Avatar
The only problem I have had is aiming the dang things, sort of hard to do when they are not in the car. So what I came up with ( while wandering down the fastner asile at HD ) is this.... ( all measurements are rough, dont quote once you get in there youll see what you need ) Take a 2x6in piece of sheet metal bend and drill so it connects to stock mounting point on the lights. Take 1 dremel and a few cutting disks and cut a channel down the middle of the sheet from, oh let's say 4-5 inches ( again rough ). Purchase 4 fender washers, 2 bolts, and 2 wing nuts. Drill a hole along the center line of the E36 stock fastners on the mounting bracket. See where I'm going here??? Fasten sheet piece to lights, put washer on bolt, insert bolt through sheet bracket and light bracket, add washer. Then aim lights, (yep if you fix the top first then you can use this sliding bracket to raise and lower the bottom of the lights to aim) tighten wing nut when they point where you want.
Old May 27, 2005 | 01:21 PM
CyMax's Avatar
Ohhh and tools you WILL need, even if you don't use the sliding bracket idea.
a 3-5 lb sledge ( yes a small handled one )
a dremel and a half dozen cutting disks
or
a grinder, I perfer the control of the dremel
Plenty of brat wash ( if your from my neck o the wood you know )
Everything else is obvious ,, eerrrrrrrr should be. Best o'luck!!
Old May 27, 2005 | 01:56 PM
mtnbikeair's Avatar
i used a pair of pliers, a hammer, and thats it. I used the pliers to rip the metal that was in my way because i was too lazy to go get a cutting disc for my dremel, and the hammer to make the bracket fit into the car.
Old May 27, 2005 | 01:58 PM
Scope's Avatar
Im izz sexay
If I can put cefiro's in with using my dremel for the first time then you can do it. I learned how to use a dremel and install something that doesn't fit all in one day.
Old May 27, 2005 | 02:05 PM
mtnbikeair's Avatar
And he still has all of his fingers to type that message with.
Old May 28, 2005 | 09:15 AM
nForce's Avatar
The Computer Guy
Were do I get a wiring harnesses at? Does the internetautomart guy sell it
Old May 28, 2005 | 10:47 AM
3rdgene's Avatar
look at ebay for that got mine for 50 bucks with bulbs and the i got the headlights for 40 bucks..just have to take the time to find it at a decent price.
Old May 28, 2005 | 03:19 PM
nForce's Avatar
The Computer Guy
will these work? http://cgi.ebay.com/ebaymotors/ws/eB...977219480&rd=1
Then how do I get a wire harnesse cant seem to find one.
Old May 28, 2005 | 04:17 PM
«§»Craig B«§»'s Avatar
go to autozone/advance auto/pepboys/napa/walmart and buy two 9005 sockets and two 9006 sockets
Old May 28, 2005 | 04:44 PM
mtnbikeair's Avatar
Yeah, i felt like an idiot when i went into auto zone and said i needed headlight sockets for e36 bmw lights, and the guy was like uhh isle 2 and i never have to ask where stuff is and i felt very inferior at that moment.
Old May 28, 2005 | 07:13 PM
nForce's Avatar
The Computer Guy
LOL FUNNY STUFF, I have 2 9004 in right now will those work?
Old May 28, 2005 | 07:22 PM
If you can manage to fit 9004 bulbs into the lights then yes. Otherwise, no. It's not even close.
The point of BMW lights (for some people) is to use the better 9005 and 9006 bulbs, not the crappy 9004.
Please check out the websites on the headlight install for more info.
Old May 28, 2005 | 07:27 PM
nForce's Avatar
The Computer Guy
Wat u think of this bundle package 2x 9005 2x 9006 not bad price too. http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW Will that work? No how do I wire these guys?
Old May 29, 2005 | 06:29 AM
3rdgene's Avatar
those work....but u still need the wiring harness.....or 9005, 9006 sockets to have a way to plug them up. look around the site there is atleast 10 active threads that explain all of this.
Old May 29, 2005 | 07:06 AM
nForce's Avatar
The Computer Guy
http://www.procarparts.com/store-det...=onlinestoreDB Can one find that cheaper with the wire harness. I couldnt find anything cheaper, I found the harness on ebay for 36 bucks and the E36 vary from 50 to 100 plus shipping. Would that work
Old May 29, 2005 | 08:47 AM
whitemax28's Avatar
the tool needed to do all the cutting, where can I find that at auto zone also?
Old May 29, 2005 | 08:48 AM
mtnbikeair's Avatar
A dremel would be best found at Home Depot or Lowes, or a store that sells power tools. I know the autozone near me doesnt have any.
Old May 29, 2005 | 11:12 AM
xnyc's Avatar
sears, homedepot, lowes, have most of the dremels. the wire harnesses are either 4 or 5 bucks each depending on what store you go to. autozone, rs strauss, pepboys and napa all have them. shouldnt cost you more than 22 bucks
Old May 29, 2005 | 01:06 PM
goon9's Avatar
...could just solder the wires to the bulbs.......
Old May 29, 2005 | 03:44 PM
internetautomar's Avatar
mod or sell?
Old May 29, 2005 | 05:29 PM
goon9's Avatar
Easy now... I bought upgraded harnesses.
Old May 30, 2005 | 08:38 AM
Scope's Avatar
Im izz sexay
I got mine off of eBay. 15 shipped yo!!!
I suggest getting atleast 50 heavy duty cutoff disks. I used almost 100 if not more on my cefiro conversion.
Old May 30, 2005 | 10:31 AM
tripleGmax's Avatar
did you get an actual dremel brand rotary tool or a knock off? i bought a knock off at meijer for 10 bucks. broke 3 of them all within 2 weeks, took them back of course and got new ones.
when i was done with it i took it back once more....im bad, but it was junk. i recommend an actual dremel brand rotary tool.
Old May 30, 2005 | 10:52 AM
goon9's Avatar
A dremel with a WAND. The Wand makes for more precision and comfort.
Old May 30, 2005 | 10:55 AM
tripleGmax's Avatar
dang thats a good deal, who is the seller?!?!
Old May 30, 2005 | 11:03 AM
Wiking's Avatar
InStallation is easey...No need for dremel, just go photoShoppin...
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
Superbform
Aug 11, 2015 08:10 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
