Windows
Lately My Driver side window goes down but when i press the switch sometimes it wont go up but then sometimes it does. I almost sure its not the regulators. because I checked and it looked ok. but if I press the down part of the button and then real quick press up It will go up. Its probably the switch right? sometimes this doesnt happen and sometimes it will. Like I said before evertything looked fine. So should I try to find a control peice to replace it? Or is anyone parting it out Ive got a 91 GXE auto.
thanks
thanks
Try taking apart the switch panel and cleaning the connectors. it's a common problem. You'll likely run into the same problem on another panel if you buy a used one, so you might as well try to fix yours first.
REDinLV
Aug 15, 2024 12:30 AM
