Broken crank snout in a VG motor
Old May 31, 2005 | 09:17 PM
oldngivout's Avatar
Willing to learn
Has anyone here ever seen this happen?
I have a 93 GXE with a broken crankshaft. Took me and a buddy forever to find the problem. The car would actually still run, although not very well. Finally noticed the crank pulley was wobbling during a compression check, which yielded numbers like 75PSI across the board. When the crank bolt was removed, the end of the crank just fell off.
Obviously this engine is junk now. I think it would be way too much trouble to replace the crank in a 192K motor when a salvage yard replacement will be nearly as cheap.
Thoughts?
Old May 31, 2005 | 09:52 PM
subs1000w's Avatar
common, um not really but it has happened to a few people
just replace the engine
Old May 31, 2005 | 09:53 PM
maximagxe90's Avatar
Hi,
how did the crankshaft broke,
did you do anything to make the crankshaft broken,
was the crankshaft already broken when you bought the car,
Old May 31, 2005 | 10:06 PM
mtcookson's Avatar
most likely the accessory belts were over tightened or possibly it had been hit somehow in the past. either way, i'd just go to a salvage yard and pick one up for a couple hundred dollars, swap it in, and call it a day.
i've heard of that happening before and that's definitely one of the few ways to destroy a vg. otherwise these engines are absolutely awesome and nearly indestructible.
Old May 31, 2005 | 10:29 PM
or another way to destory a vg by the belt breaking,
Old May 31, 2005 | 10:35 PM
VEvolution's Avatar
I miss my VE
maybe call in for a low mileage VE JDM mated to a 5spd VSLD tranny
Old Jun 1, 2005 | 04:17 AM
disgruntled's Avatar
and cram that into a 92 and up SE?
Old Jun 1, 2005 | 05:54 AM
95turbo gxe's Avatar
well I dont say it cant happen but they dont happen to offen
Old Jun 1, 2005 | 07:52 AM
nismosleeper's Avatar
As far as problems with the vg30e (there aren't that many), it is common, i bought a car with one broken, and like you, it took me forever to figure it out, and went the salvage yard route. I can get a 105K compression checked VG30e for 105.
Old Jun 1, 2005 | 12:30 PM
$105 is that right that is a dam good deal.
I dont beleive it
Old Jun 1, 2005 | 05:56 PM
Originally Posted by 93turbo gxe
$105 is that right that is a damn good deal.
I dont beleive it
Call 1-(918) 583-7283, it's 130 without the core/bad engine. They did have 3 they were trying to get rid of, but i saw one in front of the office yesterday, so maybe only 2 left.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
TKHanson
Nov 24, 2018 01:39 AM
zmcneely13
Sep 26, 2015 02:26 PM
