AC Compressor not engaging
Old Jun 3, 2005 | 06:20 PM
djx82's Avatar
Hi guys.. my AC worked few days ago.. and now when i turn on the switch, it does not engage with the Compressor. The Shop took a power tester and connected straight to the battery, then it turns on. I thought it was a fuse or Manual Climate Control Unit, so i took apart the MCC and resoldered everything, but still the same story. Can anyone help me out? thanks
Old Jun 3, 2005 | 07:59 PM
vansskaterfreek's Avatar
check the freon, you might be out of freon
Old Jun 4, 2005 | 12:48 AM
Wiking's Avatar
Originally Posted by djx82
Hi guys.. my AC worked few days ago.. and now ...
Check out also the 3 relays: u might be outta contact...
Then see for the looking glass (5.)... check: http://www.cardomain.com/ride/748507/7
Old Jun 4, 2005 | 09:11 PM
djx82's Avatar
i also filled up Freon, which was about 1.8 lbs.. and the compressor still did not turn on. I resoldered all the parts in MCC again today, but no difference. Does the Thick Blue wire which controls the air duct or (the thick flap all the way on the left side of MCC) have anything to do with AC not engaging? because two wires that connects to that board was cut off. Please help me out.. and the RAD FAN relays need to be checked up? where do you get the parts if they are bad? thanks alot guys
Old Jun 4, 2005 | 09:44 PM
geoff.doctor's Avatar
this is a question for ya, how much did the Freon cost you? I am having the same problem with my car, but I dont want to fill up if its expensive of if there is a leak.
Old Jun 5, 2005 | 04:42 AM
Wiking's Avatar
Just a sidenote: If I understand right [the greenpee] globAll WarMup
freon -hoax laws have made that stuff Illegal. Those behind this shceme, are now gouging the price of the replacement stuff, which quite probably is more dangerous toxic. Take a look: http://www.junkscience.com/
05RLS2
Sep 27, 2015 09:24 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
