throttle body
Old May 17, 2001 | 04:43 PM
atulb84's Avatar
How do you clean the throttle body/products needed and how long does it take?
Old May 17, 2001 | 06:03 PM
Chris Gregg's Avatar
Get Off My Lawn
Get some Throttle body cleaner at Auto Zone along with a cleaning brush for alumninum mags so you don't scratch everything up with too stiff a brush. Make sure you contact Nissan first if removing the intake manifold, some of the gaskets where on back order last time I asked. The brush, by the way, will fit between the butterflies when cleaning.
Old May 17, 2001 | 06:15 PM
Maximamike's Avatar
How's the engine swap going, Chris? Pics, pics, pics!!
Old May 17, 2001 | 06:48 PM
«§»Craig B«§»'s Avatar
to do a really good job, you might want a brush, but it's really not necessary
Also, for the VE, there are no gaskets to replace like the VE
just go to local auto parts store adn look for 'throttle body cleaner or air intake cleaner'; shouldn't be more than $5 or so
as for the procedure, it's very easy. just take off the plastic piece that connects to the throttle body (a few hose clamps and some pulling required). If you're not sure exactly what the throttle body is, follow the air filter back on the plastic tubes until you hit the metal part with two cables attached to the top (one for throttle, one for cruise). once you have the plastic piece out, put some rags under the TB and start spraying with your cleaner. Open the TB and spray all around where the valve meets the outside
car may be a little hard to start afterwards, but it should smooth out in a few min
Old May 17, 2001 | 07:09 PM
Get Off My Lawn
Okay, Okay! I've not used up the role yet. I've just finished painting the TURBO 3000 dust collector from the top of the engine, the valve covers, and the timing belt cover. Did you know playdough works really well for those hard to mask areas when painting? I think my son got mad at me! I've got my ecu on the way to JWT and the Cams are on the way to Schnieder! I will finish off the role first of next week and post them. But, funds are really short but I promised pics, I will deliver!!!!
Old May 17, 2001 | 08:15 PM
Maximamike's Avatar
Sweetness
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
