Nissan Factory Service Manual Sucks!
Old May 17, 2001 | 07:55 PM
superdesi's Avatar
My 91 FSM does not show how to change the distributor cap and rotor.
I had to go buy a Chiltons to provide some light. But its information is also vague.
To change the cap and rotor, do I have to unsrew the two or screws I see there?
Once I replace these parts, do I have to set the timing?
I dont have a timing light.
Old May 17, 2001 | 08:10 PM
DanNY's Avatar
Ad·min·is·tra·tor
well the FSM is for a lot of the nissan tech and etc..you wonder why they don't put in there how to change oil? the cap and distributor are very easy to change. simple tune up job. if you need a more simple manual then yes go for the chilton.
Old May 17, 2001 | 08:20 PM
superdesi's Avatar
Actually Danny, in my FSM they DO show how to change the oil.
Old May 18, 2001 | 03:25 AM
Cincy94Max's Avatar
If your so unhappy with the manual, sell it someone on the board here. There are plenty of people who would love to take it off your hands. Ngthing for instance has been looking for one. As for it not showing how to replace the distributor cap and rotor, why would Nissan ever show consumers how easy a job like that is when they can not put it in the manual and force most people to go to the dealership to get it done. For the majority of the population, how to change the cap and rotor is not general informantion, and that is all the FSM was designed to provide.
Old May 18, 2001 | 06:17 AM
Matt93SE's Avatar
STFU n00b!
Uhhh, cincy, you're a little backwards there...
the FSM was designed for Nissan Techs, NOT the general public. This is the book the mechanics use to diagnose and fix problems on your car when you take it to the shop.
As for the cap and rotor, there are 4 screws total that you have to remove in order to replace the whole thing.
there's 3 on the distrib cap, in a triangle shape.. remove those three, then the cap will pop off. there one on the side of the rotor.. it may be an allen head screw- I forget now. been a while. but remove that and slide the rotor off the shaft- REMEMBER which direction it was pointing!
Now just slide the new one back on and put it in the same position. when you tighten the screw, it'll go back to where it was.. there's a flat spot on the shaft, or the shaft may be keyed.. I forget which one now. but it'll go back on exactly where you pulled it off.
Now screw the cap back on. I think there's a rubber gasket on it too, so make sure you replace that when you're putting it back together, or the car will run like crap every time it rains or you run through a puddle.
once you tighten the 3 screws, just reconnect all your plug wires and fire that puppy up! make sure you get all the wires in the correct place- the cap and wires are all numbered, so only a doofus would screw it up- plus the wires are short enough, they should only go to one socket before runnign out of cable.
Now see how easy that was? now do you see why it wasn't in the FSM? In fact, it probably IS in the FSM, it's just hard to find. I could never find the stuff I needed in it.. by the time I gave the book to my GF and had her find it, I had already figured it out myself most of the time. oh well. there ya go.
Old May 18, 2001 | 07:08 AM
DanNY's Avatar
Ad·min·is·tra·tor
hmmm maybe i should study that bad boy again.. i always zoom past the maintence part. i guess i stand corrected.
Old May 18, 2001 | 07:29 PM
superdesi's Avatar
Thank you Sir !
Thanks so much.
Would I have to set the timing after I replace the cap and rotor? I read that timing is adjusted via loosening the distributor hold-down bolt.
Is one of the three bolts that hold the cap in place the distributor hold-down (timing) bolt?
Old May 18, 2001 | 07:41 PM
atulb84's Avatar
FSM WANTED
i am lookin for a FSM for a 93 Maxima. Let me know if any of you are lookin to get rid of yours and its in good shape.
Old May 20, 2001 | 06:23 AM
Cincy94Max's Avatar
wait a sec...
Sorry for the totally incorrect information. But what do they call the manual that comes with the car?
Old May 20, 2001 | 09:16 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: wait a sec...
"owner's manual"
Old May 20, 2001 | 10:54 AM
Cincy94Max's Avatar
Re: Re: wait a sec...
"owner's manual"
I think the kid in your sig pic is talking about me.
Old May 20, 2001 | 11:27 PM
ngthing's Avatar
man, you've got a great memory ;p i didn't even remember i was looking. ;P
Old May 21, 2001 | 08:02 PM
90maximaSE
Are you an idiot, you don't know what you are talkin about.
Old May 21, 2001 | 08:30 PM
Cincy94Max's Avatar
Why thank you. I thought that I made my stupidity quite apparent by my remarks early in the post, but your reminder was much appreciated. Oh and by the way, as a lurker, most people on the board will not respect any of your "flame" comments as well as I will.
Old May 21, 2001 | 08:38 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
HEHEHE....
that was pretty late!! kinda rude too....
Old May 23, 2001 | 09:21 AM
Matt93SE's Avatar
STFU n00b!
And Admin has just been informed of your behavior.. good day to you, and hopefully you'll grow out of your immature state soon.
MatthewsMaxima
Sep 11, 2015 03:21 AM
KGMtech
Aug 18, 2015 09:21 AM
Team STILLEN
Aug 10, 2015 04:29 PM
