Help...Need Ideas!
Old Jun 20, 2005 | 05:05 AM
Airacuda's Avatar
Help...Need Ideas!
My 91 SE VG with 245K miles started skipping above 2500 rpm's.
It only does it when it's warmed up.I changed the cap,rotor and put on a new fuel filter....same.Then I jiggled allthe wire connections under the hood and made sure all vacuum lines were connected.........Now the car started idling at 1500 rpm's
Drove for a day and tried the wiring connections again.Now I have a missing cylinder,#1 actually........I gave up and took it to the dealer.
They had it for 3 hours friday and had not found the problem yet.
I thought it would be in and out.......Hell,I was giving them Ideas!
So.............any Ideas?
By the way Hi,this is my 1st real post.been watching you guy's for years though,have a 94 GXE also with 230K miles.Your forums have saved me lots of trouble and money in the past.Thanks.
Old Jun 20, 2005 | 05:17 AM
Greeny's Avatar
¯\(°_o)/¯
Fuel injector maybe?
Old Jun 20, 2005 | 05:48 AM
Wiking's Avatar
Originally Posted by Airacuda
...So.............any Ideas?...
Idea 1.: Get u car off-out from the shop.
- Start troubleshooting systematically by first describing symptoms in detail, (skipping is too broad). Figure out which may be come same source. Then list uself what has been done.
- The new problem, high idle, is possibly IACV hose leak; jiggle it again. Use liquid seal if u cannot get the hose tight.
- Replace ign wires with real wires; throw the soot hoses out.
- Do groundigs, start from distributor: http://www.cardomain.com/ride/748507/10
- Next, dont wiggle. Clean, add contact grease:
http://www.cardomain.com/ride/748507/14
Old Jun 21, 2005 | 08:53 AM
Airacuda's Avatar
Thanks for the info.The car is supposedly now fixed.Something in the distributor was out of whack and they replaced the distributor....ouch!Anyway i would like to get a shop manual or Chiltons book,any one better than the others?
Old Jun 21, 2005 | 09:21 AM
Wiking's Avatar
Did u get your supposedly bad distr back? ...possibly swapping corrected the mentioned grounding problem: install it back, and no problems.
Dont touch chiltons crap but in most desperate situation - and be directed to ditch...
Check my web page for manual -links.
Old Jun 22, 2005 | 11:54 AM
Airacuda's Avatar
I could have got the dist back but of course they wanted me to pay the core charge.The car runs great though.In the future I hope to do my own repairs but I was in a rush this time and It sure cost me!
Old Jun 22, 2005 | 12:07 PM
Tarzan's Avatar
cuda: If only one of the cylinders was skipping, that could not have been a distributor. Distributor is dumb - all it does is turning the rotor. It has no functionality to do something wrong on only one - if it's bad, it does it to all 6.
I made it a rule long ago: do not take the car to a shop before asking here. Saves me tons of money.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Justin Kroll
Oct 1, 2015 07:03 PM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
