anyone with a VE and strutbar! springs goin on tomorrow
i bought a 1st generation strut bar off nevin this week. So far i'm really happy with the difference it's made. The steering is alot more responsive. I had to move my spark plug wires though. I disconnected the plastic retainers from the bracket, and simply pulled them back. Now they're just resting against the strut bar. did anyone else do this differently? also, i have like 1-2/16th's of an inch between the upper plenum and the strut bar. I THINK it is hitting when i pul low RPM starts. Anyone have this problem? anyone fix it? it's just really close. Tomorrow i'm gonna put my ST springs on. that oughta really tighten it up too. i'm stoked.
by first generation, i don't mean 1st gen max, i mean the first strut bar that courtesy put out. oh yeah. also, i have it adjusted to as wide as i could get it and still get it on the bolts, then zipped her down with the air gun. should i keep it like that, adjust it to neutral, or try to tighten it so it pulls the struts together.
i posted this a couple of days ago with no response.......
my dad and i finally got around to doing this project. as you know there is a problem with fstb's fitting properly over the ve engine. the bar must be bent, and the ac hose must be bent out of the way as well. what we did was cut off part of the mounting bracket, and welded tabs onto these. but these tabs are higher, giving more clearance, and make it shorter, so the ac hose doesnt need to be touched. these pics were taken right after we finished, but i need to go back and do some metal filing and some painting.
Prewinding tension into it defeats the purpose of the bar itself.
litch
123
Jan 4, 2024 07:01 PM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
