a/c problems
Old Jun 22, 2005 | 10:12 AM
sapp99's Avatar
a/c problems
Not too long ago i started noticing my a/c control panel has a problem. it works sometimes and other times it does not work at all like the push control lights don't come on and neither does the fan like its totally dead and then othertimes it comes on with no problem and works great could it be a short in the circuit or blower relay gone bad also where is the blower relay located
Old Jun 22, 2005 | 10:45 AM
Wiking's Avatar
For um is full of A/C threads, check ouch.
Click on tHere ↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓
Old Jun 22, 2005 | 11:33 AM
sapp99's Avatar
well all i need to know is where the blower motor relay is located and i don't see it on that webpage
Old Jun 22, 2005 | 11:41 AM
Wiking's Avatar
Originally Posted by sapp99
... i don't see it on that webpage
Hmm. But u might see a link to maint manual.
The fan sw and/or resistor assy may be also faulty.
clic on http://www.cardomain.com/ride/748507/7
Old Jun 22, 2005 | 01:41 PM
disgruntled's Avatar
sounds like a loose wire problem.
Old Jun 22, 2005 | 04:32 PM
sapp99's Avatar
what wire would be loose cause all the wires on the unit are connected tightly
Old Jun 23, 2005 | 04:13 AM
sometimes the wires leading to the unit may seem to be connected tightly, but in actuallity, it is not making perfect contact, so just one method for you to try is to try and shake the wires leading to the control unit ( there should be 2 - 3), if that doesn't work, then you can concentrate on other troubleshooting method.
Old Jun 25, 2005 | 11:15 AM
djx82's Avatar
that PICTURE is the fan sw? where is it located? please help
Old Jun 25, 2005 | 11:32 AM
Wiking's Avatar
fan speed resistor clic: http://www.cardomain.com/ride/748507/7
Old Jun 25, 2005 | 01:12 PM
«§»Craig B«§»'s Avatar
check out my climate control swap page on www.geocities.com/craigbrace
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
pears
Sep 18, 2015 05:25 AM
EdRomo86
Sep 12, 2015 07:49 PM
