Rev Limiter
That is because the redline is at 6700rpm. Don't recommend going above 6200. IIRC, Matt93SE said that the input shaft bearings on the transmission are only rated to 6200rpm. Going higher = dramatically shortened bearing life.
I thought the rev limiter is a mechanism that Nissan installed in order for people to not burn their engine once they reach higher RPM's.
As for the powerband, in first gear it still pulls after 6200 rpm's.
JoshG
51
Sep 21, 2015 10:41 PM
