installing water temp gauge
Old Jun 28, 2005 | 05:33 PM
max723's Avatar
is there any write up or link to install a water temp gauge. Mine stopped working, is it posible that there is an air bubble in the system?
Old Jun 29, 2005 | 01:42 AM
Wiking's Avatar
There is a bubble... how big and does it matter is the issue. Fill/Bleed the system...see tha stickies. Check the sender resistance and that its wire is connecTed. Rrplace sender if no good. Next replace the gauge:
There is ALL info u need, = if u clic on the LINKS ↓↓↓↓↓↓↓↓↓↓
Old Jun 29, 2005 | 08:03 AM
max723's Avatar
couldnt find the procedure for bleeding, should i just run the car and loosen the bleeder screw for a while?
Old Jun 29, 2005 | 08:23 AM
Wiking's Avatar
Ask site managers...
Basically yes, complicated hosing may hide bubbles; seek that from THE manual, it tells to jack up front... On ficcult cases I drive one hour 2000rpm or above, bleed valve and/or some other high hose loosened =leaking juts a little, adding coolant.
MaxLife17
Jun 27, 2019 01:37 PM
captchaos
Mar 15, 2016 12:18 PM
lux97Max
Sep 4, 2015 05:42 PM
Johnny9595
Sep 3, 2015 05:18 AM
