What are your car plans for the summer
Old Jul 6, 2005 | 12:07 PM
  #121
Jeff92se's Avatar
I'm needing a caw
Okay....again wha???? How about a few paragraphs buddy?
Originally Posted by MrGone
knock sensor
Old Jul 6, 2005 | 12:10 PM
  #122
MrGone's Avatar
He wants to drive his car off a cliff because his knock sensor is giving him crap (along with some other minor annoyances). I just think he needs to install his AASCO
Old Jul 6, 2005 | 12:16 PM
  #123
Jeff92se's Avatar
I'm needing a caw
He won't get much air with the bad ks. Should just bypass it and to the jdm ve gods.
Old Jul 6, 2005 | 12:17 PM
  #124
Mizeree_X's Avatar
Getting back to his roots
Wha?
I was referencing this post: http://forums.maxima.org/showpost.ph...8&postcount=11
It was a joke.
Old Jul 6, 2005 | 12:21 PM
  #125
Jeff92se's Avatar
I'm needing a caw
What was MrGone referring to?
It was a joke.
Old Jul 6, 2005 | 12:29 PM
  #126
Mizeree_X's Avatar
Oh, well yeah my KS is dying, but most of my driveability issues went away after I replaced my fuel pump (which died completely). So yeah, there was a period of about a week last month that I really DID want to drive the car off a cliff.
Old Jul 6, 2005 | 12:30 PM
  #127
MrGone's Avatar
JDM like woah!
Old Jul 6, 2005 | 12:31 PM
  #128
Jeff92se's Avatar
I'm needing a caw
When you quote this?
Not unless I have to
the local motor ***** should have just bought himself another 9months-year before he has to worry about messing with the engine again
  #129
Jeff92se's Avatar
I'm needing a caw
That's it? You would have driven my car off 10 cliffs by now.
Old Jul 6, 2005 | 12:34 PM
  #130
Mizeree_X's Avatar
Actually, I probably would have just lit yours on fire before that ugly gold color made my eyes bleed.
Old Jul 6, 2005 | 12:35 PM
  #131
MrGone's Avatar
I was trying to tell you you've already had your "major" engine trouble for this 6month block.
in another 6 months you'll be due for an engine swap
Old Jul 6, 2005 | 12:36 PM
  #132
Jeff92se's Avatar
I'm needing a caw
Your jealousy honors me.
  #133
MrGone's Avatar
after a while you look past the color and just see the mods
Old Jul 6, 2005 | 12:37 PM
  #134
Jeff92se's Avatar
I'm needing a caw
When did you originally state it? You quoted it.
Old Jul 6, 2005 | 12:38 PM
  #135
MrGone's Avatar
page 1
post 27
I was just realizing I thought VE's came with Fidanza's, because all the ones I've worked on in the past year have Fidanza's
  #136
Mizeree_X's Avatar
True.
Old Jul 6, 2005 | 12:40 PM
  #137
MrGone's Avatar
True.
A VE at 7200rpm will make you forget alot of things
Old Jul 6, 2005 | 12:41 PM
  #138
internetautomar's Avatar
mod or sell?
wth? haha. Geez. Around here, there are pawn shops all around. They don't have that ghetto stigma anymore. You see them across the street from casinos now too. haha
here they still do.
I'll bet the casinos own half the pawn shops around them, easier to make you go broke faster.
Shawn - I only use 6 point on my car. 12 points are the devil's work unless you have a 12 point bolt (airplanes mostly or some ARP fasteners)
  #139
Jeff92se's Avatar
I'm needing a caw
I'm stock.............
Old Jul 6, 2005 | 12:43 PM
  #140
Jeff92se's Avatar
I'm needing a caw
You won't use 12 points but will use metrics on sae nuts/bolts?
here they still do.
Old Jul 6, 2005 | 12:44 PM
  #141
MrGone's Avatar
here they still do.
I've never had a problem with 12points
I hate using wrenches though, well except the snap-on's I'm borrowing, I dont want to give them back
  #142
MrGone's Avatar
Me too .
Old Jul 6, 2005 | 12:45 PM
  #143
Cliff Clavin's Avatar
Way out West
RTFM
Adjust the floats for corners, Not sure what carb you have so cant help too much on the rich part. Just add more air or do what I said first and EFI w000w000 . I believe its a Holley so floats should be fairly simple.
The only time I'll ever do that is if it doesn't require that much torque, and I'm using a 6 point. Then again I dont have to since I have a healthy collection of SAE and Metric 6pt and 12pt from uber tiny to about 24mm/1-1/4th 1/4", 3/8" and 1/2" . Using metric 12points and any wrenches is pretty much just asking for it.
I have the factory service manual for the truck, but some goober put an aftermarket carb on. I have never worked on a carb and Doug was going to help me through it. I don't want to start something I am not sure I can finish, without the right tools and an fsm that shows a totally different carb.
The choke is electric, so I just have to give it power, probably off of the ignition somewhere with a fuse. I have read that these old Dodges don't have a very good electrical system. It has been really warm lately, so I haven't needed the choke. I was just going to do that while we were in there.
Old Jul 6, 2005 | 12:48 PM
  #144
MrGone's Avatar
cant be worse than a Nissans wiring
hey it only costs beer, can't beat that
well, unless he drinks faster than he works
Old Jul 6, 2005 | 12:50 PM
  #145
Ninty-two-se's Avatar
Maxima: Fix ABS system/brake fluid leak, Find and fix my small oil leak, fix the rust in the rear door sills and in the drivers side fender well... maybe take a look and see if it qualifies for the rust recall(hopefully not)... put the eclipse Head unit back in.
Rx-7: Finish breaking in the rebuild, new tires, Autocross it, some various body work that needs to be done.
280zxt: Finish the body work and sell it...then pick up a 240/280z
I also need to pick up the 86 300zx that someone is selling down the road from me if I can get it for less than $500.
Then college...
Old Jul 6, 2005 | 12:51 PM
  #146
Jeff92se's Avatar
I'm needing a caw
I guess Shawn says to adjust the float levels a bit higher? As far as richness goes, I would guess you need some different jets. I believe the choke just needs 12v.
You mention the previous owner put an aftermarket carb. So I'm guessing he just used whatever jets, float level etc.. that came with it. It's probably all wrong. How does it run otherwise?
I could get the cat out easy if I trusted my wooden garage floor a little more
The carb needs adjustment (it's running rich and sputters around corners) and the electric choke needs to be wired and hooked up. I can probably do the choke, but meh. I barely even have any SAE tools. They are all metric.
Old Jul 6, 2005 | 12:56 PM
  #147
MrGone's Avatar
wtf .
  #148
Jeff92se's Avatar
I'm needing a caw
Yes it can. There are ALOT of cars that have worse wiring than Nissans. We are doing an engine swap on a Lexus ES250. That wiring is nightmarish vs the VE. The entire VE engine harness unplugs and just peels back out of the way. This ES250 is impossible.
hey it only costs beer, can't beat that [img]
  #149
Jeff92se's Avatar
I'm needing a caw
wtf .
Old Jul 6, 2005 | 12:58 PM
  #150
MrGone's Avatar
I meant more the quality of the wire. Granted exaggerated abit
The maximas connectors aren't bad at all, better than alot of cars
Old Jul 6, 2005 | 12:59 PM
  #151
MrGone's Avatar
the bold part of the quote
I dont get why you said "shawn says"
Old Jul 6, 2005 | 01:03 PM
  #152
Jeff92se's Avatar
I'm needing a caw
You said "adjust the floats for corners". You can only really adjust them 2 ways correct?? Up and down. So I would guess "UP". Unless that's is incorrect? Either way, since Chris has no experience with carbs, "adjusting for corners" is a fairly ambigous statement.
And I also assume there is no richness adjustment other than replacing the various jets in the carb. You didn't address this portion of his question. But I guess if it only bogs when hitting the gas, he might have to adjust the arm that controls how much gas is sprayed in when the pedal is pushed. If it runs rich all the time, then it's probably a jet problem. If it idles rich, it could be his idle jet?? Dunno.
Old Jul 6, 2005 | 01:09 PM
  #153
MrGone's Avatar
yeah, but the hard part is I dont know what carb he has. There is going to be different levels and ability to adjust a Edelbrock/Weber vs Holley vs. Barry Grant.
I was trying to find out what one he had so I could help out more
Old Jul 6, 2005 | 01:11 PM
  #154
Jeff92se's Avatar
I'm needing a caw
Don't all these have removable jets for general a/f and idle a/f? Differences come in with vacuum secondaries or pumped secondaries.
Old Jul 6, 2005 | 01:45 PM
  #155
505max94se's Avatar
What amp? Have you already done brakes? Back treating you better?
w00t for school
A US AMPS TU-4360 tube amp. I already have one, I just need one more because I'm doing an active crossover set-up with 3-way components in the front and coaxials in the rear.
I don't have a bbk but I have new brembo blanks and pbr/axis metalmaster pads. It stops good enough for me (for now).
My back is doing great. I'm almost completely back to normal. Physical therapy helped ALOT.
Old Jul 6, 2005 | 02:04 PM
  #156
Dysfunctional
im hopefully going to get my motor back soon, i got it built rather nicely. i got custom pistons, rods, cams, intake manifold, exhaust manifold, trottle body, bored .20 over, stand alone, injectors, fuel pump, cryo treated engine, balanced motor, uhh ... what else axles, 3 inch exhaust, liquid to air intercooler, garrett T88 turbo, custom intake tubing, intercooler tubing, custom exhaust - full 3 in with a side exit at the passenger door.
uhh .. what else ??? there's got to be something else ... ill think of it
Old Jul 6, 2005 | 02:08 PM
  #157
Alex_V
Nice, finally some one willing to go standalone. Gotta see that when thats done.
~Alex
  #158
MrGone's Avatar
Edelbrocks dont have jets for idle a/f, just a screw. Chris probably has a Holley or Weber, not sure.
D-sta sucks, needs to get online
Time to go work on the car and mail some stuff, thats my summer project
Old Jul 6, 2005 | 02:10 PM
  #159
tripleGmax's Avatar
i got it.... you want my used magnaflow, and youll need these adjustable camber bolts of mine. u still got the paypal addy?
the links are in my sig
Old Jul 6, 2005 | 02:11 PM
  #160
tripleGmax's Avatar
page 5 gave me a headache
