window wont go up
Jul 7, 2005 | 08:05 PM
hey guys. my drivers side window wont go up. it ll go down but not up. is there a way i can wire it to go up and just stay that way until i get a new control thing for the window
Jul 7, 2005 | 08:17 PM
bump........
Jul 7, 2005 | 08:33 PM
you can try and pull it up by hand, and then duct tape the glass into place for the time being. Noted, duct tape will leave a sticky residue, so when you are done, you will need some of that goo-b-gone stuff.
Jul 7, 2005 | 08:45 PM
when you push the window up botton what happens?
if you here the sound of the motor turning but the window not moving its the regulator
if you dont here anyhting its the motor or the switch
chances are id be alot easier to just take the door apart and fix the problem instead of bandaiding it
and your right about the duct tape residue being a pain to get off
Jul 7, 2005 | 08:47 PM
i dont hear anything when i hit it to go up. i think its the switch because it goes down. is there anyway to put a wire thru it or something to like jump the connection and make go up meanwhile
Jul 7, 2005 | 08:52 PM
to clarify things abit, when you press the switch for the windows to go down, do you hear the motor turning with it, or the glass simply fell down? Having this information might help.
Jul 7, 2005 | 09:02 PM
the glass goes down when i hit the switch. the motor works fine then. but when i hit the button for it to go up it wont go up. the motor turns with it when i want it to go down. but not when i want it to go up. it hasnt fallen out of track or anything like that
Jul 7, 2005 | 09:12 PM
alright, got cha, do you have AIM? I can send you something very useful right now
Jul 7, 2005 | 09:14 PM
yeah at domlcardio. please thanks
Jul 7, 2005 | 09:15 PM
its about to start raining
Jul 7, 2005 | 09:39 PM
reset relay man...disconnect battery..and reset the power window relay..im from 4th gen forum..
Jul 7, 2005 | 09:42 PM
how do u reset the relay
Jul 7, 2005 | 09:44 PM
i think i shocked the whole damn thing trying to jump the connections
Jul 7, 2005 | 11:30 PM
I have the same problem, and I know what the reason is. at least on mine, the window tilts forward, so it sorta wedges and stops. it's probably due to the seat that holds the underside of the window being damaged or bent or something. try gripping the window and tilting it backwards and pulling it up while pressing the button. that might help.
Jul 8, 2005 | 01:28 AM
Quote: how do u reset the relay
Balooney 're set'. Check out http://www.cardomain.com/ride/748507/13
The whole system is processor controlled network - from drivers door. Pass door needs "when & direction" -datasignals to start to work. Now it does not receive DATA and/or +12V at request and/or your motor & mech does not work.
Power is delivered only when the DATA is sent and demand -signal is active, there is no way to direct bypass the pass doors... without direct supplying +12V with extra wiring, that is.
Jul 8, 2005 | 04:28 AM
reseting a relay
Jul 8, 2005 | 04:59 AM
Quote: reseting a relay
Could one reset also sparkplugs? How?
Jul 8, 2005 | 01:51 PM
My window on the passenger side is starting to sound very sluggish when I put it up. It sounds like the electric engine or whatever is starting to fail. I just hope it breaks when its up already.
Jul 8, 2005 | 04:09 PM
Quote: My window on the passenger side is starting to sound very sluggish when I put it up. It sounds like the electric engine or whatever is starting to fail. I just hope it breaks when its up already.
preventative maintnance is your friend
Jul 8, 2005 | 06:00 PM
check your window regulator and motor, best way to do this is by lowering the window and check to see the motor on the bottom, the lines that lead the window up and down get tangled and might only work one way or only go up half way.. take a peak..
Jul 16, 2005 | 11:02 PM
window glitches
I to also have problems withe my windows not going up and I can not figure it out. Sometimes when attempting to raise the FR or RR window from the drivers position(actually any switch) they will not go up but I can hear a clicking sound from the door of the window I'm try to move when I hit the switch. Some times it will work and sometimes not but no matter what I hear that click. The LR doesn't work at all(no clicks).
What cuases this and what to do?
My repair manual from Chilton or Alldata just show a object with numbered wires but not the internal workings. Does anybody have anything more than this ?
Jul 17, 2005 | 05:00 AM
check the stickies, under FAQ, and click on Craigh's website, then check a section called replacing windows regulator and motor.
If it's still clicking, then it might be the regulator got tangled up, but the motor is still good. no click either means the motor died, or no signal/power is getting to the motor because a switch died.
Jul 17, 2005 | 08:34 AM
you probably need to pull the door panel and inspect.
Jul 17, 2005 | 11:15 AM
What is the click noise I'm hearing exacty. I never have any grinding or other odd noise so I would not think the regulator has a stripped part. Is what I am hearing the motor bumping on a stuck regulator? If so how would you explain moving window down couple of inches, press up- will not move but will click, press down- will click and goes down, press up wil go up and the next time it won't go up but will click. This happens randomly of course and I never hear any sounds of damaged components. Window movement is smooth and consistent when moving.
Jul 17, 2005 | 11:39 AM
Quote: What is the click noise I'm hearing exacty. ...
At least in to the schema there has been drawn a circ breaker... look up tHere.
Jul 17, 2005 | 12:10 PM
I have never heard of a circuit breaker clicking at exactly the same time you press and release a windows switch. There has to be some time for the overload to trip it or time to reset once overload is gone if it is a thermal type. It sounds more like there is a relay in there.
Jul 17, 2005 | 08:09 PM
I think your best bet now would just to pull the door panel and inspect, just takes a little time, but its free. IMO, it's much better than beating around the bush suspecting this and that right?
Jul 17, 2005 | 11:20 PM
Quote: ... like there is a relay in there.
...cannot hear the sound or timeline. No relay in my doors. Sound might come from the motor mech?
On pass door, pressing button sends data request. Drivers door 'answers' by giving the supply voltage... The data signals are very weak, condensed water or pinched cable ruins connection.
