My 94 Maxima is sluggish and shaking at 45 MPH and 1500 RPM
Old Jul 8, 2005 | 09:00 PM
doodoodoo's Avatar
94 maxima GXE, auto, 166000 mile.
My Maxima tends to be sluggish and starts to shake at 45 MPH and 1500 RPM. This is more obvious when going uphilll. At above 2000 RPM, my car runs great.
I replaced the spark plugs and transimission fluid recently because of this problem. The tranny was rebuilt at 137000, all the 6 injectors are working well. The distributor cap was replaced about 2 years before, but the timing was not checked. The knock sensor and O2 sensor are not replaced since I bought this car at 10700. Also, it appears that the (vacuum) tubes on the engiene are kind of loosening, they can be moved easily.
I tried to search the forum for this problem, but I couldnot find the answer to it. There are so many possible causes for the sluggish driving. Does anyone know about this specific case? I am going to work on my car tomorrow, your help is appreciated.
Old Jul 8, 2005 | 10:43 PM
Tom's Avatar
Tom
Do check your ignition timing. It can make a world of difference if it's set too retarded, then the car will feel sluggish. I assume you changed the distributor rotor with the cap. If not, replace it, it's cheap.
Old Jul 9, 2005 | 12:25 AM
souporman's Avatar
If the vacuum tubes are loosening...then y don't you replace them? Its not hard and you can usually find kits of silicone hose in various sizes.
Old Jul 9, 2005 | 12:32 AM
Wiking's Avatar
Originally Posted by doodoodoo
...couldnot find the answer to it. There are so many possible causes for the sluggish driving. ....
Multiple causes = one answer not possible.
Go through all of these, after that no need to ask, clic on: http://www.cardomain.com/ride/748507/1
=cap, rotor, scrap soothoses, plugs, connectors cleanup (16hrs), groundings,
all airleaks =hoses have to be repaired AND so on.
Forget one nuance = keep on stuttering - here most want to own ol' civic...
Old Jul 9, 2005 | 09:56 AM
doodoodoo's Avatar
I found that the TPS connector is rusty. After I cleaned it up, the problem seems disappeared. I will test drive more to confirm this.
Old Jul 9, 2005 | 11:52 AM
Wiking's Avatar
Keep on testin... make sure nobody will not repair the leaking hoses
TPS is for cold engine mgmt plus A/T.
Old Aug 4, 2005 | 09:37 AM
cmwill1284's Avatar
what did you use to clean the TPS connector just out of curiosity?
Hondarydr
Dec 30, 2024 06:15 PM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
MaxStock
Aug 12, 2015 08:33 AM
Gsantos79
Aug 8, 2015 07:41 AM
