Doing timing belt, what parts do I need?
Old Jul 10, 2005 | 05:29 PM
ArcticDC5's Avatar
Ok, so I am gonna do the timing belt pretty shortly here and I have the following items to shop for:
-timing belt
-timing belt tensioner
-water pump
-front main seal
-drive belts (power steering, alternator)
What else am I missing/should I replace when I am in there?
Old Jul 10, 2005 | 05:38 PM
Pervis Anathema's Avatar
- tensioner spring
- camshaft oil seals
- air conditioner belt
- thermostat
Old Jul 10, 2005 | 07:47 PM
maximagxe90's Avatar
replace the antifreeze if it hasn't been replace before,
and flush the coolant system if it hasn't been flush before,
you guys forgot the timming belt also,
Old Jul 11, 2005 | 12:23 AM
mattcomet82's Avatar
i just did this last weekend. unless you have a leak, there's no reason to pull the timing gears and change those seals. if it ain't broke, don't f*ck with sh*t.
Old Jul 11, 2005 | 02:09 AM
The 60,000 miles maintenance as prescribed by Nissan includes the Camshaft oil seals. Good thing you waited. You saved 15 minutes of work and a few bucks so that you can do it all over again when they start leaking.
Waiting until something breaks to fix it is irresponsible and foolish. Preventative maintenance is the key to avoiding breakdowns and accidents.
Old Jul 11, 2005 | 02:58 AM
MrGone's Avatar
Old Jul 11, 2005 | 03:26 AM
maxima94ever's Avatar
i have a 94 se it has 146,000 miles and i believe the timing chain has never been changed since i had the car from 49,000miles, can smebdy explain it to me if it has to be changed at 60,000. thank you
Old Jul 11, 2005 | 03:27 AM
MrGone's Avatar
no it does not
Old Jul 11, 2005 | 03:30 AM
ok, thank you.
Old Jul 11, 2005 | 03:47 AM
MrGone's Avatar
yeap
Old Jul 11, 2005 | 03:53 AM
i realize im taking a big chance by not doing it but when u dnt have the dinero to do it it just has to wait. and since im 52 yrs old i only use the car to go to church and supermarket. can u tell me what wld happen if it goes while im driving.
Old Jul 11, 2005 | 06:26 AM
rawmax1's Avatar
If you have a se DOHC with a chain you shouldn't have nothing to worry about. Just normal maintenance
Old Jul 11, 2005 | 06:27 AM
tripleGmax's Avatar
junked motor pretty much.
Old Jul 11, 2005 | 06:44 AM
Matt93SE's Avatar
STFU n00b!
cam and crank seals should ALWAYS be replaced when you do the timing belt.
in the case of a VE, you don't have any of those issues and simply need to replace the crank seal whenever it starts leaking. often it's the oil pan lip seal below it that leaks though. still an easy fix. remove crank pulley, clean area with brake cleaner or other solvent, let dry, then dab some RTV silicone around that lip seal. it will stop the leak around the seal since there's no actual oil pressure there- just the stuff dripping back into the pan from the heads and timing chain.
Back to the VG... you might want to make sure your dealer has a spare crankshaft timing gear and the metal plate thingies in stock. often those things are beaten up/knicked/scratched while trying to pry it off to get to the crank seal. the gear itself is about $35 and the plates shouldnt' be more than a couple of bucks.
just throwing that gear away and replacing it will take less time and money than trying to resurface the gear after prying on it for 45 min to get it off...
oh.. and penetrating oil is your friend. trust me on that one. keep that crankshaft well oiled the whole time you're working on the top end and it will help when getting the crank gear off.
Old Jul 11, 2005 | 08:51 AM
ArcticDC5's Avatar
I am 6k miles away from the change. Think I should wait it out a few more thousand miles or go ahead and get it done? The engine is making a whining noise from inside the car on that side of the engine where all the belts are. Not sure if its a tensioner making that noise or the water pump.
Old Jul 11, 2005 | 08:53 AM
Jeff92se's Avatar
I'm needing a caw
Make that sig smaller today.
Old Jul 11, 2005 | 08:58 AM
Greeny's Avatar
¯\(°_o)/¯
A Maximaniac with acura sig.....hmmmmmmmm....
Old Jul 11, 2005 | 09:28 AM
internetautomar's Avatar
mod or sell?
I have an acura in the garage too
pics
Old Jul 11, 2005 | 10:45 AM
Greeny's Avatar
¯\(°_o)/¯
pics
Thats a car???
Old Jul 11, 2005 | 11:00 AM
mod or sell?
Thats a car???
I only said acura, not neccesarily car.
actually it's only missing a headlight and hood. the rest is there
Old Jul 11, 2005 | 11:10 AM
kcidmil's Avatar
hey internetautomar... what all does your Timing Component Kit consist of?
Old Jul 11, 2005 | 12:34 PM
mod or sell?
Belt and tensioner
Old Jul 11, 2005 | 12:51 PM
does that tensioner come with a spring
Old Jul 11, 2005 | 01:00 PM
Matt93SE's Avatar
STFU n00b!
don't worry about the spring. you only use it once to help rotate the tensioner when you first put the belt on. once you tighten the nut on the tensioner, that spring doesn't do anything until you take the tensioner off again.
Old Jul 11, 2005 | 01:42 PM
mod or sell?
no .
Old Jul 12, 2005 | 03:27 AM
Thank you i do have a dohc.
Old Jul 12, 2005 | 04:15 AM
And the FSM does a beautiful job of precisely illustrating how a properly adjusted tensioner should look.
Old Jul 12, 2005 | 07:21 AM
Matt93SE's Avatar
STFU n00b!
Actually the tensioner is in the correct position...
the problem is it mentions that you turn it clockwise, instead of counter-clockwise.
what's even more fun is lining up the distributor. If you follow the picture of where it should be once its installed, it puts it about 30 degrees off--which makes it real fun when you fire it up because the exhaust valve is open when the ignition fires. do it with the Y pipe off and you shoot fireballs out of the ex manifolds! makes some REALLY cool sounds too! :
If you follow the marks on the distributor and install it like the instructions say, then it will line up. the thing should be pointing roughly 7-8 o'clock if you're standing at the front of the car.. the FSM shows it to be pointing around 11 o'clock. doh!
Old Jul 12, 2005 | 08:08 AM
DanNY's Avatar
Ad·min·is·tra·tor
yeah the FSM sucksssss with the dist clocking.
Old Jul 12, 2005 | 09:46 AM
ArcticDC5's Avatar
Where can I get torque specs for everything I will be taking apart/re-assembling online?
Sorry for my large picture of my RSX type-s, my picture shrinking program is on my home pc. I will reduce the size once I get home tonight from work.
Old Jul 12, 2005 | 09:47 AM
Jeff92se's Avatar
I'm needing a caw
Make that sig smaller or be banned. 2nd warning. You have exactly until I eat lunch in two hours.
Old Jul 12, 2005 | 09:52 AM
Wiking's Avatar
Jeff, I want u opinion on this pic/issue, pls: http://forums.maxima.org/showthread.php?t=416523
Old Jul 12, 2005 | 09:54 AM
Jeff92se's Avatar
I'm needing a caw
What pic? TripleG's? Yeah we should ban him for that. haha. At least it's not HUGE. And at least it's a MAXIMA.
Old Jul 12, 2005 | 10:00 AM
Wiking's Avatar
...no I mean this mechanical problem my brains have, on that mentioned thread:
pic: http://memimage.cardomain.net/member...7_364_full.jpg
tripleGmax's Avatar
ummmm, i followed the sig pic guidelines of size, but i made it smaller than the largest possible because im courteous to others. you cant get respect when you put a huge full screen image of an rsx as your sig. you could however take the pic link out of your sig.
i also did the rhd swap in 2 hours
oh and torque specs can be found in the FSM on page 21 of section GI (general info)...or a chiltons or haynes will have that too
Old Jul 12, 2005 | 10:22 AM
kcidmil's Avatar
i was going to say... even my pic is bigger than yours gregg. Erty76 did mine... so any complaints can be forwarded to him
Old Jul 12, 2005 | 04:18 PM
PulsarDriver's Avatar
I'm just past 118k on mine (if you believe the odometer, heh) 2k from what I believe is the change interval :|
I really don't want to do the belt/stuff...or pay someone to do it for me :| Seems worth it though, I guess. I love my beater...it runs and drives great, despite its looks.
Old Jul 12, 2005 | 05:09 PM
GRNMAXDMON's Avatar
can u guys clarify this for me:
i took off my distributor to change both valve cover gaskets on my new motor for my '93 and did not notice that the rotor moved out of place. well, i ended up puttin' the cams and crank at factory timin' marks and installed new timin' belt and i also double checked that piston #1 was at TDC but what i didn't realize was the rotor in the distributor was pointin' to spark plug terminal #3 instead of #1??? now i was told that since piston #1 is at TDC the rotor should also be pointin' to spark plug terminal #1 under distributor cap. <--- is this correct???
Old Jul 12, 2005 | 07:27 PM
ArcticDC5's Avatar
So, back on course...Does anyone know where I can get torque specs at for the timing belt job?
Old Jul 12, 2005 | 08:42 PM
Matt93SE's Avatar
STFU n00b!
Open your handy FSM. look on page EM-32. align the marks on the distributor as shown in the pictures, then install it. If you are standing in front of the car facing the back, it should be pointing at around 7-8 o'clock position, toward the front right corner of the car.
It SHOULD NOT be pointing at the 11 o'clock position as shown in the FSM.
As long as you align the marks according to the picture above it, then it will go into the right place. if it doesn't fire, pull it out, turn the engine a full turn, then do it again.
