coilover setup
Old Jul 14, 2005 | 09:32 PM
  #41
bvtran's Avatar
94c Big Max
good point, Matt
Old Jul 14, 2005 | 10:19 PM
  #42
Cliff Clavin's Avatar
Way out West
I am trying to figure out exactly where this thread is going. I read through all of these lame posts and came up with very little. Did the company quote you a price? Please answer all of Matt's questions, too.
I seriously doubt that anyone on this board would pay over $1k for an unproven coilover set up. That would equal about 1/3 the value of most 3rd gens.
Old Jul 15, 2005 | 06:51 AM
  #43
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by maxedout92max
oem struts... i guess but ill ask to make sure...to the ??? which one has turbo ... the one on page one ... mine... but its getting bmw rear light shaved in, 5 speed convert.,rear disc brakes, and more engine work like turbo, injectors, ect....
i tell people to get aftermarket struts for eibach springs...you think the OEM will work well for coil overs?
Old Jul 15, 2005 | 07:01 AM
  #44
VEvolution's Avatar
I miss my VE
Im still a bit confused about what coilovers actually are.. What makes them different then the regular Eibach/Koni set-up?
Old Jul 15, 2005 | 07:09 AM
  #45
DanNY's Avatar
Ad·min·is·tra·tor
look in the pic...see that spring...it sits on an adjustable sleeve (sleeve can be moved up or down). since you can move that sleeve you can also adjust the ride height. the spring you can also get in various spring rates and lenghts.
eibach/koni set up...the spring perch stays at stock location. eibach figured out the spring rates for you and set height.
Old Jul 15, 2005 | 07:34 AM
  #46
cardana24's Avatar
Blown
The white car looks like a ford thunderbird And what kind of power does the turbo maxima with the Z31 swap put down?
Goodluck with the coils!!!!
Old Jul 15, 2005 | 01:10 PM
  #47
VEvolution's Avatar
I miss my VE
Okay, so basically coil overs are adjustable. Is that the official name for them, because someone keeps telling me that I have coil overs on my rear. I didn't really argue since a coil spring goes over the shock. Can our stock set-up be called coil overs?
Old Jul 15, 2005 | 01:25 PM
  #48
internetautomar's Avatar
mod or sell?
yes.
but these days when some one says coil overs, they're normally talking about adjustable coil overs.
kinda like talking about an intake.
Old Jul 15, 2005 | 01:29 PM
  #49
DanNY's Avatar
Ad·min·is·tra·tor
yes...coil overs are adjustable. your stock suspension is not a coil over set up. more like macpherson set up.
Old Jul 15, 2005 | 01:30 PM
  #50
tripleGmax's Avatar
but its a coil over the strut.....
Old Jul 15, 2005 | 02:04 PM
  #51
Matt93SE's Avatar
STFU n00b!
in all technical terms, our suspension that uses MacPherson struts is a coil-over-strut setup. But it is not to be confused with racing type coilovers.
the big difference between coilovers and our stuff is that coilovers are adjustable. some only allow for ride height adjustments by turning the lower spring perch, and others have ride height, spring travel, and multimple shock damping adjustments. the more goodies on it, the more expensive it is.
Old Jul 15, 2005 | 02:20 PM
  #52
tripleGmax's Avatar
matt, how is it that other cars have aftermarket coil-overs but ours dont....i only mean what is our limiting factor basically.....
Old Jul 15, 2005 | 02:25 PM
  #53
Jeff92se's Avatar
I'm needing a caw
3-gens have one of the shortest shock travel lengths out there. That's why when you dump your 3-gen with really low lowering springs the shocks blow very easily.
Old Jul 15, 2005 | 03:00 PM
  #54
Matt93SE's Avatar
STFU n00b!
Yup.. what Jeffy said.
that's reason #2.
reason #1 is the 3rd gen MAxima is a freaking 4 door family car! there's little to no demand for stuff like this.
reason #3 is the rear strut housing is part of the axle stub assembly- just like the blue one in the above pic.. that makes an aftermarket coilover very $$$$$$ because they have to make/copy/remachine that part.
reason #4 (why ground control and other sleeve-over places don't make kits) is because the struts are insanely short- the 3rd gen uses a 12" long front strut housing. not even the Stanza, Sentra, Altima, Eclipse, Neon, Miata, etc use struts that short. so you can't even steal a strut from somewhere else and use it. there's just nothing to fit it, and you're SOL on getting anything custom in small enough quantities to make it worthwhile to a manufacturer.
Old Jul 15, 2005 | 07:29 PM
  #55
MrSector9's Avatar
So this place wants $900 american dollars to install crappy *** ground control coil over sleeves?
I want to say no offense but I probably will offend if you are even thinking about this.
My buddy got some ground control coil over sleeves for his tercel (funny i know.. least now it is respectable wiht a 4efte swap and eibachs and lot sof other goodies) anyways they are the worst bunch of junk I ever seen,Crappy made parts out of crappy aluminum with single rate springs.Any body that woudl pay that much money to do something so stupid belongs in a sunfire.
specially if it is using oem struts.. i would almost gurantee a car with tockico or konis with eibachs would outhandle that in a second.Also the fact that you have to have your car realigned everytime you change the ride height would be stupid.
Like matt said it is a 4door family car and I must say if it was a kit to make a set of real racing coil overs fit on then it owudl be interesting,but i am petty sure anyone with any mechanical skill coudl do this swp themselves... why i do not know
Old Jul 15, 2005 | 08:04 PM
  #56
anaximander's Avatar
that's reason #2.
Aren't short shock travel lengths (#2) and #4 directly related? More importantly, what does that mean in terms of the effect on the car? Does it give the 3rd gen more potential than comparable cars? I've driven in almost all cars you mentioned above (except stanza and miata) and it seemed that the 3rd gen has best stock handling.
Old Jul 15, 2005 | 08:08 PM
  #57
tripleGmax's Avatar
more potential for what? def. not coilover suspesion, because there is way too much to figure out since its soo short. read matts first post on page 1 where he asks all those questions, those are the things making it hard, otherwise matt would have coilovers on his ride and probably be selling them.
Old Jul 15, 2005 | 08:11 PM
  #58
Not coilover potential, I know it's extremely hard to design them. I was thinking of handling in general.
Old Jul 15, 2005 | 10:31 PM
  #59
Dysfunctional
so,
get this done, then have them make a second set
and have them send it to me!
Old Jul 16, 2005 | 07:06 AM
  #60
Matt93SE's Avatar
STFU n00b!
Our cars don't have much potential in all honesty.
my car is about as good as it gets without a roll cage and a race shop actually building the parts.... and my stock 240 with sticky tires and 100k miles shocks will already take corners just as well.
These cars also eat tires like there's no tomorrow. A weekend at the track costs me a 1/2 set of tires. and on 17x8 wheels and good tires, you guys know a full set (mounted) runs about $700.. so $350 every time I go tot he track, or I can run the same tires on the 240 and get a season out of them. hmmmm.
The Maxima also has a horrible weight distribution problem. it's around 60% front, and to make it handle better, you would need to remove 10% of the weight OFF the front, or move it to the back.. you can get close by swapping in a VQ (-125lb), removing the A/C (-30lb), and moving the battery to the back (40lb shifted to the back),
but you're still a FAR cry off of good weight distribution.
And when you did that, it would change so many other things about the car. roll centers, ride height on both ends, spring and shock rates would need to be changed again.. it would be rebuilding a completely different car.
If this were a $40,000 car with real potential, it might be worth all that. but nobody in their right mind is goign to go through all that work and expense for a $2500 family car. You'd be better off buying a used E36 sedan or a WRX for the same money and have a car with excellent handling from the factory.
Old Jul 16, 2005 | 01:24 PM
  #61
VEvolution's Avatar
I miss my VE
Oh well.. So much for the four door sports car.
P.S.- Why does the Max eat tires faster then the 240?
Old Jul 16, 2005 | 01:32 PM
  #62
Matt93SE's Avatar
STFU n00b!
Maxima: FWD, 3600lb (with driver), 59/41 front/rear.
240SX: RWD, 2800lb (with driver), 54/46 front/rear.
so the Maxima has ~1070lb on each front wheel that does ALL the work. the front tires must accelerate, stop, and turn the vehicle. the rear wheels are just dragging along for fun basically.. They have about 740lb on each wheel and don't have to do much work.
the 240, on the other hand, has 760lb on each front wheel that must stop and turn.
the rear wheels are driven, so they get to share some of the work. They have about 650lb on them doing the acceleration only.
that's a greatly simplified version of it, but the big issue is that the Maxima is a FWD nose-heavy pig emphasis added just so everyone gets my point ). To make them corner at 1g, you're putting some HUGE stresses on the front wheels, with not a lot on the rears. The 240 is much more balanced- it sees drastically less stress on the front wheels and much more on the rears.
Old Jul 16, 2005 | 03:16 PM
  #63
VEvolution's Avatar
I miss my VE
Yeah, I see what your getting at. But 3600 for Maxima? I don't know about that man.. More like 34. Stock Curb weight is around 3150 for an auto GXE, that already includes the full tank, and your average guy is about 175-200 lbs. Plus, if your going for a track set-up, your bound to have reduced the weight somewhere. Still fairly heavy for a car like this.
So where would you say the 3rd gen thrives better at full potential? At the strip, or upon the twisties?
Old Jul 16, 2005 | 05:26 PM
  #64
Interesting, I thought my front tires were wearing faster because the front alignment/tire balance is more prone to getting messed up. Frequent tire rotation is the key then.
Old Jul 16, 2005 | 08:01 PM
  #65
mod or sell?
Cavalier
Old Jul 16, 2005 | 09:12 PM
  #66
Scope's Avatar
Im izz sexay
What I really hate about this thread is how soo many people are downing this setup. If Matt, Dan, Jeff, and like two other people hadn't said anything then mainly everyone would have been like I'm down for a set. More than likely no one would have even considered the questions Matt has proposed up front. Instead of going against him someone could atleast give him props because there are only two other people in my knowledge that has tried a coilover setup. Madmax(I think that's it), and Matt.
When they finish this product get some slammed pics. Getting a pic of this on a black max with a stillen kit and 25% tints = teh hottness.
Old Jul 16, 2005 | 10:07 PM
  #67
Way out West
damn, Matt, how big are you?
I weighed my car with no interior at a Oregon DOT truck scale and it was at 3000 lbs with 1/2 tank of gas. With me in it (185 lbs), that's still under 3200 lbs.
What you say is true about the handling and stuff. The car is nose heavy and eats tires if you don't have everything perfect. It handles better than most fwd sedans, but is laughable compared to a sporty car like a Miata, 240sx, MR2, etc. -- the kind of cars most people autocross.
Also, I would not have even consider a coilover set up on my Maxima. It's just too much money for a car as old as mine. I can barely justify paying for used Eibachs for it.
Old Jul 17, 2005 | 12:48 AM
  #68
lophix's Avatar
extra sound insulation, additional mods (sway bars, sturt bars, sub frame connectors, lower tie bars, rear tie bars) + audio components, wheels + tires, bigger brakes.......all these things add up to a pretty hefty vehicle.
Old Jul 17, 2005 | 01:16 AM
  #69
VEvolution's Avatar
I miss my VE
Yeah, good point. Forgot about all of Matt's goodies.
Old Jul 17, 2005 | 08:24 AM
  #70
mod or sell?
Madmax024 (pat) took his out because it just wasn't worth it.
Matt IIRC has a bumpsteer issue with his.
so, 2 knowledgable people have problems with them, you really think you won't?
Old Jul 17, 2005 | 02:15 PM
  #71
Scope's Avatar
Im izz sexay
I wasn't saying I won't have issues with these I'm just saying that everyone is knocking this guy from atleast trying to be innovative. Only two other people have tried coilovers. I thought Madmax thought they were too rough so he got rid of them. To my knowledge the only people that are posting good info on trying to tackle these issues are Matt, only because he has past experience. Everyone one else is just playing follow the leader.
Old Jul 17, 2005 | 03:39 PM
  #72
HTPerformance's Avatar
Old Jul 17, 2005 | 10:04 PM
  #73
maxedout92max's Avatar
the swap has 330hp right now... not saying whats done to the engine tho dont know how it is tho ... it was at the shop getting its goodies and they told me they dynoed it and told me 328 so i dont know if it hooks up in 1st or 2nd cause then the car went to get some lights shaved in the rear and painted
Old Jul 17, 2005 | 10:26 PM
  #74
thanks vg man most of these people just paly follow the leader ... they dont know if anyone really drives a max and has money to do what ever they want to it... people do drive p.o.s and got mad work done to it... thats what most people dont get .... its not how the car looks or sounds.. its what it can do, thats what most sleepers are!!!!!!!! they are car that you wouldnt give a second look... all im sayin is some one might wanted to get a set you dont know who has money and who dont( you if your driving a p.o.s and down talking someone that is just making conversation with others and posting new **** that people dont know that is out there... you see some one said " whats coilovers" so if you dont have nothing good to say about someones questions or post they help them or dont say nothing dumb a$$.
matt and mr. gone this is not for u guys cause ur old skool and have tried everything but all the other followers you just told me what you know and thanks cause these are question that i have to ask when getting them made...but still just atleast ive done that but good luck trying.... im not crying just getting tired of people with there 2 cents these days...
Old Jul 17, 2005 | 10:51 PM
  #75
Jeff92se's Avatar
I'm needing a caw
If these issues were sorted out, I'd have them years ago. Sorry to be a "follower".
Old Jul 18, 2005 | 03:30 AM
  #76
Scope's Avatar
Im izz sexay
I should have said just about everyone else. There are only like four people that knows what they're doing to even tackle these issues. One of them are you.
Old Jul 18, 2005 | 03:35 AM
  #77
MrGone's Avatar
I thought the reason why Pat stopped running them is because he couldn't drive a block without wearing out his strut mounts?
Old Jul 18, 2005 | 03:36 AM
  #78
Scope's Avatar
Im izz sexay
Did he go OEM with the mounts or did he try polyurethane?
Old Jul 18, 2005 | 03:37 AM
  #79
MrGone's Avatar
beats me, I didn't get involved in that headache.
Old Jul 18, 2005 | 06:21 AM
  #80
Matt93SE's Avatar
STFU n00b!
no, he didn't use ANY upper spring perches and had the coilover springs sitting directly on his factory upper spring seats. :
